Question about JVC Everio GZ-HD7 Camcorder
Im getting a Hard Disk error
Im not sure what's the problem but, that damn thing hangs up and shows that disk is full. In the middle of copying files to my PC.
I need to play with the buttons(on/off menu) a lot to get it back to show be the harddrive.
this camera was too pricey to be doing this to me.
  • surisetty Oct 17, 2008
    I have the same problem and tried all the solutions described here for no joy.
  • rich medrano
    rich medrano May 11, 2010
    Could your disk be full? Or maybe fragmented? Just wondering because you're right, the camera shouldn't be doing that. If you go to >start>my computer it will show you the disk drives. Right click on your drive and go to properties. It will show your disk usage.
    If your drive is fragmented too much go to >programs>accessories>system tools>defrag and do a defrag. then restart your computer.
    I kind of think it might not be the camera but try this and see.
Ill try to be a little clearer
Disk is not full, i never wait till theend to unload my videos. I try to derfagment it every time I unload my videos.
This problem happened to me twice, luckly was able to recover.
I plug the camera to the USB port, computer sees it. I start copying files to my comp using the camera software, than everything freezes. I unplug the camera switch to the recording mode and it showes me "disk full error" , "hard disk error". At that time the computer stops seeing the camera.
I spend good half hour messing with it, turning it on and off and playing with buttons. After a while I get it to work and my recordings show up again.
I suspect a conflict with the software or possibly hard disk is over heating.
So far I was able to live with this problem.
Cheers
Posted on Sep 13, 2008
Window gets stuck on "disk
It is clear your hard disk has developed errors.
Let the disk check run completely. If is stops in the middle, that shows their is a major problem with your hard disk.
If you cancel the disk checking, the computer hangs because some of the system files are already damaged due to the hard disk error.
One thing you can do is to backup everything and format the hard disk and reinstall the operating system and the software.
If the hard disk error is propagating type (i.e. the amount damaged keeps increasing), you will have to reinstall the OS every 2 to 4 weeks.
In this case it is better to replace your hard disk.
Sep 11, 2011 | Acer TravelMate 290 Notebook
I have sandisk cruzer 16gb. When i try to copy file more then 2gb i get an error: the disk in the destination drive is full. why I'm getting this error? thanks
If the flash drive is not full its because the format that a flash drive uses is FAT32 and that wont let you copy anything over 2Gb's im pretty sure
Aug 09, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Problem in external hard disk
Type this command in command prompt " chkdsk /r " in specfic disk prompt (eg) f:\> chkdsk /r
Oct 05, 2009 | Western Digital My Book Essential Edition...
Sata HDD very slow
Dear friend you need a sata board to get maximum speed of sata driver connect it directly to motherboard sata jack converter does not give full sata speed
Jul 22, 2009 | Hitachi Deskstar T7K250 250 GB Hard Drive
"a disk error occured during a write operation" in file summary
It's not a problem with the hard drive, that's for sure. It's something with the music file. You will be able to see that if you move the file to a removable media or another hard drive you will most likely not be able to edit the properties. I don't know what the problem is though, just saying that the hard drive isn't bad. If you want a clarification, you said you had a Dell Computer. When booting up hit F12 and run Diagnostics. It should go through an auto set of diagnostics and then allow you to select what you want to run. Run full diagnostics on your hard drive. Any failure and you should replace the drive.
Mar 19, 2009 | Dell InspironTM 1501 Notebook
500GB MY BOOK hard drive.how to clear "disk error" & use again?
when you reboot your computer, do not have the hard drive attached. As far as the error goes, im not to sure about that.
Jan 27, 2009 | Western Digital 500GB My Book World...
Cant put files on my memory
format both phone and memory card
Jan 10, 2009 | Nokia N73 Cellular Phone
Hardrive issues
hi, remove and put the hard disk in another machine where you disconnect the cd rom and fix the hard disk so as to view two drive(c(hard disk in the machine)&e(the faulty hard disk))open c and create a folder ,open e and copy your files to c .
after remove the e drive and fix it to its machine.
format the hard disk then copy the files in c(in the other machine)using the above procedure
May 21, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Power calibration area full
There are many facts cause "Power calibration area Full" error. First of all clean up your TEMP files. Make sure DVD media you are using is supported by you DVD Writer. CDs are rather easy to write. DVD requires more precise laser beam to channel as its more dense than CD. So physical facts like dust on the lens might be a factor too. Also firmware update for your DVD Writer will be a great step. These are the main factors.
Good Luck
Dec 30, 2007 | Fujitsu Siemens AMILO Pro V2010 Notebook
Disk full message
Do a bit of arithmetic - go to each folder right click, then click on properties and take note of the size of each folder. What does that add up to? Any unusually large files? Has it been partitioned at all?
May 14, 2007 | LaCie (300728U) 250 GB Hard Drive
JVC Everio GZ-HD7 Camcorder Logo
106 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
