Hi!!
Check the Brake Pedal Position Switch on top of the brake pedal, the Lt Green w/Red stripe wire should always have 12v+, when brake pedal is depressed the Lt Green wire should have 12v+ also, if no power on Lt. Green w/Red wire, check fuse # 2 20A, if no power on Lt. Green wire when pedal depressed, REPLACE Switch, If there is power on both wires when pedal is depressed, check IVD STOP LAMP RELAY on the Aux. Relay Box 1 located at the Left Front of the Engine Compartment.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Check the wiring to the brake pedal switch on brake arm & the switch.
