Back to:
Tags:
Refrigerators
Generic problem for all Refrigerators
Amana BX21TW defrost issue
posted by 2brice on Jul 25, 2008
How often is the defrost mode to kick on and how long is it suppose to last? Is there different settings to the defrost program?
Currently the defrost seems to kick on once every 4 days and stays in defrost mode for 2 to 3 days. During the defrost mode the freezer is more like a fridge the temp is usually around 32 degrees. The fridge portion stays a constant temp (or I should say with a few degree difference).
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Refrigerators problems?
U-Line Refrigerator Ice Maker
manually cycle icemaker and unit goes thru cycle but when...
Kenmore 53642 / 53644 Side by Side...
Model #106.56532400 side by side Ice maker not getting...
Refrigerators
water dispenser doesn't work
Refrigerators
ice maker motor is turning the threaded post but the...
Refrigerators
have a whirlpool side by side with ice/water dispensor on...
Loading problems.
Repair Service
Find Refrigerator Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
