LD means long drain. Check the drain hose at the back of the machine and check for blockage at the hose attached to the drain pump. If that does not fix the problem, check the pump itself and the pressure switch.
Ld (F32) Long Drain "Ld" flashes when water level drop ain't sensed by the control. Check these things out: Drain pump fouled/clogged Drain hose too high for proper pumping. Pressure hose tubing clogged/pinched came loose from that fancy control upstairs.
Post your model number I might have a service manual and a better answer for you.
Ld (F32) Long Drain "Ld" flashes when water level drop ain't sensed by that fancy lectronic control. Check these things out: Drain pump fouled/clogged Drain hose too high for propah pumpin. Pressure hose tubing clogged/pinched came loose from that fancy control upstairs.
Hello there:
Ld
Long Drain
Ld flashes
if it takes longer than 5 minutes to pump out water to a
point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. unplug the POWER cord .or turn off the maching for 10 min and retry if this stil does not help check each of these things i have mentioned below and replace or repair as needed · Check wiring harness · Check pump motor · Check circuit board
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine. Please do rate the solution if the issue is resolved or post a comment for further assistance.
ld flashes if it takes longer than 5 min to pump out water to the point where the operating pressure switch resets.check the drain line for kinks,check drain for blockage,check pump operation.
"Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Usual causes are easy to check:
1. Unplug the washer and clean the pump strainer. It is located between the drum and the pump, and will be attached to the drum with a rubber hose.
2. Dump your drain hose into a bucket to remove any build-up in the drain hose. If possible, run an empty load, with the drain hose pointed outside.
