Question about Linksys Wireless-G Broadband Router
Router problems my mireless router cant connect to the internet. every time i install it my computer says that the router was unable to connect to the internet. i have roadrunner and it always works so i dont know why its doing this. pleas help.
  • 26 Answers
Wired internet connection not working
you must reset the router by 30 seconds and try again. Remember they have a password for wep key for access. do you do it?when you installed the router the software is you want the connection close or open?
However you must click in open network connection , and select network troubleshooter and fix it.
If the problem remain, you must go to router supplier manufacturer via ONLINE chat, and explain the problem.
or reinstall the Router again follow the steps with your disk instalation.
God bless you
Jul 28, 2013 | Zoom Computers & Internet
Set up my netgear router. laptops show that they are wirelessly connected to the main computer, but we cant get them to connect to the internet. also lost the netgear cd that came with router. do we need...
The netgear router installation will set up the internet connection during install.
Download the Router driver from netgears website and install on the computer/s then your up and running.
it appears you wireless card is seeing the router so just install the drivers and your set.
Oct 03, 2010 | Computers & Internet
Unable to access the internet via my laptop
One of two problems. The Security Key for your wireless connection is wrong, or the McAfee is causing a problem. Most likely conflicting with any other virus software on your computer. Try removing McAfee from the computer and your solution should go away. Try another virus software such as Avast! Home edition. McAfee is known for having issues with wireless internet connections.
Gary
Jan 25, 2009 | Linksys Wireless-G WRT54G Router
Unable to get laptop to connect to the internet.
I have resolved the problem by doing a system restore. I set the computer to a previous date and this seems to have sorted out the problem. I guess that I may have had a software confliction.
Many thanks.
Nov 27, 2008 | 2wire HomePortal® 1800HW Router...
Unable to connect to internet wirelessly, but i can use cable to connect then, it says the internet connect is linksys internet
Do you have a wireless card? Is it installed? linksys usually doesnt have many problems. Depending on what computer you have you might need to flick a switch or press a button somewhere to turn on your wireless nic. If you do have a wireless card look for some drivers online. I cant tell you too much without knowing what computer you have or how you have your router set up.
May 04, 2008 | Computers & Internet
Unable to access homeportal, but internet is ok?! (2wire 1800hw)
I had the same problem. I reset the home portal to factory setting and uninstalled the 2wire software from my main computer. I then reinstalled the system using installation cd that came with 2wire.
Jan 21, 2008 | 2wire HomePortal® 1800HW Router...
Linksys BEFW11S4 Wireless-B Broadband Router connection trouble
You will need to logon the router via the computer, and create a PPPOE internet connection. If you cannot connect to the router wirelessly my may need to use a cat5 cable between the computer and the router. The user manual that came with the router will show you how to do this. If you do not have the manual. Do the following: open internet explorer, in the address window type the IP of the router "example" http://192.168.2.1 your router IP should be on the bottom of the router. If not click start/run, type ipconfig at the > the router ip is listed at "default gateway".once you get to the routers logon page enter one of the following: username "leave blank" – username " admin " -or- username "admin" - password 1234 –or- leave password field blank.once logged on the router go to internet connections and select PPPOE enter the username and password provided by your ISP save the settings and you should make the internet
connection now. BPCS
Dec 26, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Wireless router WRT54G version 2
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
let me no know in case if you have any problems ...
Nov 18, 2007 | Computers & Internet
PPPoE over Edimax BR-6104K without a modem
HI,
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
Can't Connect to Internet
there is a need to reconfigure your router to work with your modem. If configured already before, then there is great chance that this has been set back to factory default.
Oct 06, 2007 | U.S. Robotics USRobotics USR5461 Wireless...
Linksys Wireless-G Broadband Router Logo
37 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
