Question about Sony IT M804 Corded Phone
Replacement AC adaptor for M804
I recently moved and can't find the ac adaptor for my IT M804 phone. Sony says they do not make them anymore. I've searched online with no luck. Any thoughts?
    Novelist:
    Scholar:
  • 125 Answers
Check the phones specifications. Usually they are either under the phone or base or on the back. There you will see the Voltage at least. Then go to your neighborhood hardware store (computer stores may have it too, sometimes) look for the adaptor that have variable voltage as well as variable plugs that will adapt to the female input sockets on your phone or phone's base. Hope this helps.
Posted on Jul 25, 2008
0xc190003 HP b010
"Gondo" <nowingspaanspam@yahoo.com> wrote in message
news:fsv880din9khpu7e9p8olvrc8uj1u1uj3o@4ax.com...
> This has been an ongoing problem with this laptop, and now I can
> hardly get it to power up at all.
> First, the AC/DC power adaptor jack in the back is very loose and
the
> power is lost intermittently when you move the jack around on the
> receptacle.
> Once the green power light does come on, you press the power switch
> repeatedly to the left to turn the laptop on and nothing happens.
Only
> by the combination of wiggling the power adapter jack around while
> pushing the power button repeatedly can you maybe get lucky and get
it
> to start up.
> I was just wondering what else might be bad internally besides the
> power adaptor jack. Possibly the connection to the power switch or
the
> switch itself? The AC/DC adaptor was replaced recently, so I'm
pretty
> sure that isn't the problem.
> It appears it will need replacement parts, so I'm looking for
> recommendations on where to find the applicable parts online.
To Fix Your Hp Issue,In Case You Still Having Problem Then Follow Us For On : HP Support
Feb 26, 2013 | HEWLETT-PACKARD Hp Ac Adapter Power...
How do i set up call forwarding for a Sony IT-M804
presently landline phones not supporting call forwardings,,however u hav that option in ur phone ,,but it does nt work
Jun 28, 2012 | Sony IT M804 Corded Phone
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Recently, the battery of my vaio died, but I could still manage by getting the power from outside sourse. However, I couldn't even turn it on last night, even though the vaio was still getting the power...
eventhough the light indicator on the ac adapter is still working, it doesnt mean that the ac adapter is still working fine..
  • the problem could be the ac adaptor itself, the dc in port of the computer or maybe the motherboard.
if the computer is still in the warranty, sony will cover the battery, ac adapter replacement, or process repair if needed. you can call them at 888 476 6972 or 239 768 7669
Mar 15, 2010 | Sony Computers & Internet
Lacking AC adaptor
Hello
Just recently i had the same problem just with my guitar pedal. My adapter broke and i had to make another plan.
So i was left with 2 options, either stop playing guitar or buy a new adapter, which is expensive. I then found a multiadaper. With this you can choose between AC or DC, and you have different options to which voltage you need to use. Best of all, it is not expensive at all and you an basically use it for everything which needs an adapter. You can buy this at any electronic shop
Really hope that this can help you
Sep 14, 2009 | Panasonic SDR-H18 USB Hard Drive
My (fat) psp isn't working without the ac adaptor
Your battery is dead. You will need to get a replacement. eBay is your best option.
Aug 26, 2009 | Sony PlayStation Portable (PSP) Console
Lightning strike ac adaptor is fried
Your phone did expirence a surge that probably blew the ac adaptor which happens most of the time, u can buy one of those universal adaptors and look on the back of the old adaptor for the output voltage it will usually read between 3 and 8 volts DC.Set the universal adAptor voltage to the setting right below the voltage output on the back of the ac adaptor.
Aug 04, 2008 | Uniden Cordless phone EXS9950
Ac-V15/V16A AC power adaptor
shop on ebay.  I just picked up one the other day for $20.  If you look for an inexpensive (or broken) camcorder you often find it comes with an adaptor and can get it the whole thing for a decent price.
Aug 23, 2007 | Sony Handycam CCD-TRV11 8mm Analog...
Sony IT M804 Corded Phone Logo
156 people viewed this question
Top Sony Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
