Question about Big Button GE 29369GE1 Speakerphone
Caller ID does not display calls, is there a battery to be replaced.
  • whkjr4 Oct 19, 2008
    Caller ID comee on and then fades...Un plug power and same thing happens.
ID NOT WORKING
I TRY EVERY THING
HELP
Posted on May 15, 2009
Me Too! L_E_M_O_N
Posted on Sep 13, 2008
How do I hide my number when calling from alcatel onetouch in australia
here you go
  • How to display or hide caller ID on my ALCATEL ONETOUCH ... support.bell.ca > Bell Mobility How to display or hide caller ID on my ALCATEL ONETOUCH Idol 3. ALCATEL ONETOUCH Idol™ 3 ... Caller ID allows you to hide or display your phone number in ...
  • Caller ID: ALCATEL ONETOUCH Fierce ' T-Mobile Support support.t-mobile.com > T-Mobile Support Learn how to use the caller ID on the ALCATEL ONETOUCH Fierce™. ... press the Phone icon. ... Hide number; Show number;
  • Can I hide my number while calling someone? ' T-Mobile Support support.t-mobile.com > T-Mobile Support Can I hide my number while calling someone? Log in; Home: Account: Billing: Coverage: Devices: Plans: Contact Us: Manage ... Caller ID: Alcatel ONETOUCH ...
  • Jul 04, 2016 | Alcatel Cell Phones
    How do i make my phone number visible to my callers when calling from a Vtech phone
    Caller ID
    If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
    Call block
    If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
    Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
    Caller id not showing
    IF youre call id is activated in the exchange by service provider , most probably the phone is faulty.
    May 06, 2014 | Lands Phones
    On Samsung jet s8000 Incoming calls display unknown caller message, but call log shows ID
    Check your Sim in another phone to confirm , if there is no CLIP then the service provider has barred you and must get in touch. Also is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
    Apr 26, 2011 | Samsung Jet S8000 Cell Phone
    No caller ID. TP company says I have service.
    • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
    • Is the battery old? - Replace the battery.
    • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
    • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
    • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
    • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
    • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
    If this does not fix your problem, contact your authorized Service Center.*
    Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
    Caller i.d. doesn't work piece of junk
    Please download this manual, and study e.g on page 21 About caller ID If you subscribe to caller ID service from your local telephone company, this feature displays the name and telephone number of the caller before answering a call (even when you are on another call). The caller ID features of this product will work only if you subscribe to caller ID service and both you and the caller are in areas offering caller ID service, and if both telephone companies use compatible equipment. Contact your local telephone company if: • you have both caller ID and call waiting, but as separate services (you may need combined service), • you have only caller ID service, or only call waiting service, • you do not subscribe to caller ID or call waiting services but wish to try them. There may be fees for these services, and they may not be available in all areas. This product can be used without subscribing to either caller ID or combined caller ID with call waiting service, although the caller ID features of this product will not function.
    http://www.vtechphones.com/docMgt/public/art/52882/6041_manual.i4.pdf
    Mar 12, 2010 | Vtech Cordless 6041 Phone
    UNIDEN TRU8888-CALLER ID DOES NOT WORK
    Hi
    Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
    If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
    When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
    When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
    You may receive any one of the following messages:
    When a private name is received; Private Name
    When a private number is received; Private Number
    When a unknown name is received; Unknown Name
    When a unknown number is received; Unknown Number
    When invalid data is received; Incomplete Data
    The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
    Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
    Please do rate the solution and revert for further assistance.
    Thanks
    Rylee
    Aug 16, 2009 | Uniden Cordless Phone
    Call waiting caller id
    did you check batterys on phone
    Apr 03, 2009 | Lands Phones
    I have call waiting and caller ID through my phone company. I have two Uniden phones--EXA17980 and EX15160 cordless phones. Both phones should display the caller ID while I am on the phone with another...
    You're right, at least one of them should. You should contact your telephone company and ensure you have Caller ID while on Call Waiting service (CIDCW) - it's not always the same as just Caller ID. Sometimes they'll want even more money. :)
    Mar 09, 2009 | Uniden Cordless Phone
    Caller ID is not working in India.
    For people who have purchased cordless phone in usa and caller id is not working they should purchase fsk to dtmf converter at any local phone shop and caller id will start working.
    Here is the article on various frequency used by various countries for caller id.
    Hope this will help you out.
    Detailed Product Description
    There are 3 major caller ID specifications in the world: DTMF, ETSI FSK and Bellcore FSK. When users buy a foreign telephone devices(such as cordless phone, fax machine or computer telephony interface), may encounter the problems of non-match for caller ID standard. This will cause the device unable to display the caller ID. EX220 can solve this problem easily. This product can receive all 3 kinds of caller ID format, and convert to FSK(Bellcore or ETSI selectable) to match foreign telephone's standard.
    EX220 has a rechargeable battery inside the device, during idle status, it gets power from the telephone line and recharge the battery, so no need to use or replace battery. Just plug one end to telephone line, and the other to the telephone device.
    For example, if you live in Netherlands, Saudi or India, the caller ID standard is DTMF. You purchased a cordless caller ID phone from US(which uses Bellcore FSK standard), or from Germany(which uses ETSI FSK standard). You won't be able to use the caller ID feature. In this case, just get one EX220 and connect it between the telephone line and the cordless phone, your cordless caller ID phone will display the caller's number immediately.
    Remark:
    1. Telephone sets for UK and Japan standard are not applicable.
    2. In some countries, users must subscribe to Telecom for caller ID service
    Feature List
    Caller ID Format Conversion --- Convert 3 kinds of caller ID(DTMF, Bellcore FSK or ETSI FSK) to ETSI FSK or Bellcore FSK(selectable)
    Date/Time Stamp --- The DTMF caller ID doesn't content date/time stamp. User can set up clock of EX201, so each call will be sent with actual date and time stamp
    Area Code Setting --- User can set up the area code, so the dial back feature can easily applied
    Rechargeable battery powered by line --- Just connect to the telephone line, the built-in rechargeable battery can get power from the telephone line, no need any external battery nor power supply
    News
    Now, Multi-Line caller ID converter is available.
    Dec 09, 2007 | Motorola Mobility 5.8 GHz Digital Cordless...
    Big Button GE 29369GE1 Speakerphone Logo
    282 people viewed this question
    Top Big Button Lands Phones Experts
    Tom Chichester
    richie46
    Are you a Big Button Lands Phone Expert? Answer questions, earn points and help others
