Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Bosch WFMC3200UC My Bosch clothes washer does not rotate. We start the cycle, the door locks and water fills into the tub, but then there is no rotation that occurs. It just sits there.
  • 1 more comment
  • rharr0 Sep 04, 2008
    Same problem , have run though service program and unit fails on motor test. Motor ohms out, voltage input correct from control panel problem points to motor control bd trying to locate part or find out if Bosch has a repair service or a 3rd party repair service.
  • paul54321 Oct 10, 2008
    I have the same problem with my bosch WFMC3200UC   I think the C stands for ****  It starts fills then drains or just sits there and the door will open but the lock light is on.
  • padcabin Nov 29, 2008
    Same machine, same problem. The service man from the place I bought it at came out and replaced the lock. Worked 3 out of 4 times after that and now just starts for a few moments, drains, and then stops with no time decrease; still 1:00 on clock.
    This is not an impressive machine for dependability for as new as it is; 2 yrs 6 months.
I'm having a hard time understanding what is happening with my Bosch. Mine is filling and then immediately emptying out. Then the door unlocks but the timer indicates 45 minutes left (or so) and the door lock light is still on. Usually the only cycle that spins now is the spin cycle, but this doesn't help me get the soap out of the clothes still in the drum.
When the machine fills but doesn't rotate, the water level seems low as well. I had a repair man out who thought it might be the door latch sensor needing replacing (honestly, my toddler was pushing that button repeatedly), but I don't think that's it.
What does work: I unplug it for a while. Then if I'm lucky and the laundry Gods are shining down on me, I can wash normally (usually I'm luckier on Permanent Press but I always used to use the Cotton side). However, once I turn the machine "off," that's it all the problems persist so I have to wash it all, one load after another.
Posted on Aug 20, 2008
How do I clean my washing machine? My clothes and the washer have a mildew odor.
Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
Aug 18, 2011 | LG WM-2277HW Front Load Washer
WFMC3200UC stops half way through the cycle and wont finish
sounds and smells like a heating problem if the appliance is not heating it will not complete the cycle and as the detergent starts to break down it makes the appliance smell
Mar 12, 2009 | Washing Machines
Washer will not spin and finish cycle.
on the lower rhs is a clean out door, use ascrew driver to spin the door loose and clean out the pump behind the door.
Jan 28, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch WFMC3200UC
No - the latch failure will prevent you from starting this machine.
It appears your door latch/sensor has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Bosch Nexxt WFMC3200UC
Bosch Nexxt WFMC3200UC Water pouring out from beneath washer. This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 15, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Door locked,wont spin or drain.
humming noise suggests a foreign object in the pump. crack open filter and drain water into a shallow tray. repeat till empty. remove filter completely and clean it. check if something stuck in pump impellor. this should be visible by looking into the filter hole
Jun 22, 2007 | Bosch WFMC 3200 Front Load Washer
Washing machine will not drain
I have a maytag washer that when it fills with water it wont drain out..the spin cycle just makes a noise and it wont do anything..any ideas what i can do to fix it thanks
May 07, 2006 | Indesit W 123 Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
562 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
