Question about Garmin nuvi 200W GPS Receiver
Windows XP will not recognize Garmin 200W
I bought a new usb cable and plugged my garmin 200w into my computer. Windows XP does not recognize the Garmin although the Garmin screen does show a picture of a computer with a garmin plugged into it. I have spent over two hours on hold and talking about five minutes with Garmin support, They can't figure out why I can't download the lates maps. Any suggestions?
  • 6 more comments
  • cirrus9977 Jul 25, 2008
    The problem is when I plug my Nuvi 200W into my computer using XP SP2, the computer does not recognize the device. I downloaded the Garmin drivers and when it prompts me to connect the device, a screen pops up saying I need to connect the device and wait 20 seconds. After I wait, nothing happens. My computer does not recognize my Garmin.
  • cirrus9977 Jul 26, 2008
    I've tried loading the Garmin USB driver. When I download the driver, and before the driver is completely installed, you get instructions to connect the garmin so the download of the driver will be completed. When i connect the device it doesn't recognize it so the driver installation stops. This is driving my up crazy !. My USb's are 2.0 and I am running XP with SP2. The USB ports are all working. I have plugged other USB devices in and they are immediately recognized.
  • Anonymous Dec 25, 2008
    I have the same problem. I think Garmin needs to hire some competent folks and recall all its faulty products.
    The owner's manual is profoundly poorly written. Garmin gets an F- for documentation.
  • iluvyersmile Jan 01, 2009
    I have the exact same problems AND I have already tried all of the solutions that were given as options. HEEEEEEEEELLLP!!!
  • chiefdon Jan 03, 2009
    Prior to connecting the Garmin 200W to a USB port, my computer recognized my Hard drive (C), two CD drives (D&E) and an external hard drive (F), connected to a USB port.
    When I connect USB cable from an unused USB port to a the Garmin 200w, two things occur - 1. My computer does not recognize my 200W unit. 2. The computer now recognizes on drives C, D & E -- No longer recognizing the external HD (F)
  • Anonymous Feb 17, 2009
    I have exactly the same problem with nuvi 250 and Windows 2000.
  • tillypops Mar 15, 2009
    won't recognise my sat nav nuvi 205 very frustrating easier to,learn map reading or googlebefore you go !!!
  • Anonymous May 20, 2009
    Same as every one else on this page......
I had the same issue. I would plug it in and it would recognize the device then it would disappear.
What I did to solve the problem was to first turn on my Gamin 200w. After it was finished loading maps then I plugged in in to the usb port. My machine recognized the device without any problems. I am running Windows Vista Home Premium. Hope that helps.
Posted on Jan 24, 2009
It turned out not to be my Garmin 200W, but a faulty USB cable. I exchanged the one that I just purchased for a different one and it works perfect.
Posted on Jan 29, 2009
I'm having this issue and windows recognized it as a garmin usb gps, then it still ends up saying there was a problem with the installation and the hardware may not run correctly. this is ridiculous - returning this if Garmin can't help on Monday.
Posted on Jan 02, 2010
I ran into this and eventually realized that the Garmin was locked up. To reboot my Garmin unit (nuvi 765T), I just needed to slide the on/off switch to the left and hold it there for about 10 seconds (until the unit powered off). Once I then turned it back on I was back in business.
Posted on Dec 26, 2009
Chiefdon was right on. I switched USB cables and it worked perfectly. I think I was maybe using a blackberry USB cable which may have been the problem.
Posted on Sep 23, 2009
Rileyjb SOLUTION #3 was correct. My computer (XP) wouldn't recognise my 255w so I unplugged it from the usb cable, powered it off and then on again, and once it was loaded up to the normal navigation start screen I plugged it into the computer and BINGO the unit was recognised. I'm downloading my update as we speak.
Posted on Mar 31, 2010
    Scholar:
  • 162 Answers
1- did you load the USB driver for your garmin unit BEFORE plugging in the unit? Is your USB 1.1 or 2.0 compliant?
Most of the time, you need to install the software first before plugging in any usb device. You can go to GARMIN.COM and download your usb driver and run it, then plug in your garmin unit. If your USB is 1.1, you may experience a problem. Also, what version of XP are you running? have you updated to SP2?
Another thing you can do is reset your USB devices. Click on START, SETTINGS, CONTROL PANEL, SYSTEM. Click on the tab HARDWARE, click on DEVICE MANAGER, go down to UNIVERSAL SERIAL BUS CONTROLER. and delete everything there. Make sure you have the original drivers for your particular system just in case windows can't recognize them. Have you tried plugging in another USB device to see if windows recognizes that? You may have a problem with your USB ports. Some Compaq/HP models, the USB ports just stop working. I had a client go out and purchase a usb card to solve the problem.
Posted on Jul 25, 2008
  • Gary Luis
    Gary Luis Jul 26, 2008
    Try this, plug in your garmin, turn it on, and run webupdater. If webupdater finds it that's all you need.
    You can also rule out the computer by plugging your garmin into another system and see if that system reads it. Then you know for sure the problem is with your computer. If the other system doesn't find it, or webupdater can't find it, then for sure the problem is with the unit. If it's under 1 year, it's on warrantee.
PLEASE talk me through as to how to update my Garmin 200W series...
Below are steps to successfully update your Garmin Nuvi GPS;
Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
Open your Internet browser of choice and type in the following web address: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27"
Download the appropriate version of the software for your computer (Windows or Apple) and Install the Web-Updater by following the wizard (accept defaults).
Click "Start," "All Programs," "Garmin" and " Web-Updater" to update your firmware and your maps. Periodically check and make sure your software is current.
Good luck.
Oct 24, 2010 | Garmin nuvi 200W GPS Receiver
Tip
Nuvi 200W Webupdate
Garmin Nuvi 200W Webupdate
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________
Download your Garmin Nuvi 200 Series manuals here.
Download your Garmin Nuvi 205 Series manuals here.
Garmin Nuvi Hard Reset Here.
Garmin Nuvi 200W Favorites Backup here
on Apr 17, 2010 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200W car cable fell apart. Bought new universal cable which charges gps in car but screen will only show a symbol (looks like a cable plugged into a computer) that's not explained anywhere in...
i have gone through more cables than you can imagine, if you plug in the cable that gives you the computer symbol,slide the power button to what would be the off position then slide it back to lock
1 or 2 slides should take it out of this mode, i had the same problem.
Feb 04, 2010 | Garmin nuvi 200W GPS Receiver
Ineed to install an update of maps on my nuvi 200w how do i do this and what cable do i need to plug into my computer?
You need a usb mini cable betwwen GPS and Computwer, You need a free garmin software from Garmin.com and a map, taht cost You 150 Euro
Nov 08, 2009 | Garmin nuvi 200W GPS Receiver
Garmin 200w goes into usb mass storage mode when pluged to charge
Steps:
1) Disconnect the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi will reboot, but remain in GPS mode!
Jun 08, 2009 | Garmin nuvi 200W GPS
Garmin Nuvi 200w shows system software missing.
I had the same thing happen. I called customer service
(1-800-800-1020). They linked to my computer (nuvi was pluged into it)
and fixed everything!
Dec 24, 2008 | Garmin nuvi 200W GPS Receiver
My windows xp does not recognize my garmin200
Go to the Garmin site and download you USB driver. Install the driver with out the GPS connected. Aftter the USB driver is installed reboot you computer and then connect the GPS. Let us know if that works.
Dec 16, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200
Windows XP is a very old system in computer years. You should probably try using on another computer that is running Windows 7 or Windows 10. If you check the Garmin website it will most likely support what I have described.
Sep 17, 2017 | Garmin nuvi 200W GPS Receiver
Proble with my garmin nuvi 200
Please go to this page and download the Garmin driver and install it.
http://www.sharc.net/nuvi_links.htm
- Jim
Dec 09, 2008 | Garmin nuvi 200W GPS Receiver
Can I find a copy of the Garmin Nuvi 350T manual online please?
Yes. There are 3 ways to charge the Nuvi. Computer USB cable, 120VAC transformer wall plugin, and the cigarette lighter DC 12V plug for your car.
May 24, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
8,191 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
