posted by tom_man9 on Jul 25, 2008
My TV just wont work like it should anymore. It just suddenly went weird on me. So i took the back off and looked around. And turned it on as well. The projectors all light up for like less than a minute then they shut off. The standby light always flashes alot. No fuses seem blown and i got a can of the that dust remover stuff. can anyone suggest any solutions that problem?
Solution #1
posted on Jul 30, 2008
If you are not a qualified service technician, I would strongly suggest you did not attempt to diagnois or "test" circuits as this could be for both the TV and possibly you. Have unit serviced by a pro technician
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 29, 2008
You should be little bit more specific. How many times does the standby light blink once the set turns off? That is an indicator for the problem with the set. Any colors showing brighter than others while the set is on? Please give us more to work with. Also, before you are removing panels, please make sure the unit is unplugged!
Suggest a new solution for this problem
Post a New problem for Sony KP-51HW40 51 in. Rear Projection
Email this problem
Email this problem
Can you Help with these Projection Televisions problems?
Sony KP-51HW40 51 in. Rear Projection...
rear projection TV would not...
I am trying to power up my TV..... Answer This...
stanby light bleeks
stanby light bleeks
standby light blinks off and on Answer This...
arched picture
arched picture
picture is arched and its out... Answer This...
your TV problem
your TV problem
If you get a solution to this... Answer This...
Repair Service
Find Projection TV Repairman Near You:
