Ac unit my ac unit stoped working. all i can hear is noise coming out from it.
  • 143 Answers
It seems the fan has stopped. Either the fan motor is bad or it isn't getting any electricity.
Posted on Jul 25, 2008
Not cooling room and every 45 seconds it makes a hum noise
window unit ac !! not a fridge . the hum you hear is the ac compressor trying to come on , but due to loss of gas charge it shuts right off again , this will require a professional ac repairman to fix this , 1st he needs to find leak then repair leak then add back lost gas charge , watch cost of all these services vs cost of entire new unit , it could get expensive
Jun 24, 2015 | Refrigerators
Multiple clicking sounds coming from AC unit before AC unit turns on or before furnace turns on.
the is a 24v wire that feeds from your thermostat to your unit, inside there is a contactor that engages, this makes a click sound as it really is a basic mechanical part the makes metal touch metal to allow current to flow through the system, perfectly normal, your hearing the low voltage engage the highvoltage at the contactor.
Jun 18, 2013 | Dometic Rooftop RV Air Conditioner
My outside Kelvinator central ac unit will not turn on. I hear a faint humming noise coming from it so it appears that it is getting power but won't turn on. My fan in the house will turn on and...
Its possible that the contactor that closes to start the outdoor unit is not pulling in and passing power. You are hearing the coil humming since it is getting control power. Also first check that breaker for outdoor unit is not tripped
Jun 22, 2011 | Heating & Cooling
My unit outside is working fine but it is making a lot of noise. All my neighbors are telling me that this is not normal. What can I do to reduce the noise. It is spinning fine but it makes loud noise.
Is the condenser coils clean..... If not take a hose and wash the condenser coils But make sure you shut the Main power off to it. Has the unit been charged with Freon lately??? If so they may have gotten it overcharged which will cause High head pressure and make the compressor noisy..... Or is it out of level and not setting on a stable surface. causing a vibration noise. You can put rubber pads under the AC if it is a vibration noise...... Also the Compressor may be going out..... It is hard to tell with out hearing it first hand....Hope this helps If you can't get it to quite down I would setup a Service Call to have them Service the AC and that you are having a loud noise coming from the unit....
May 05, 2011 | Goodman CLT48AER48 Air Conditioner
My AC unit is not working ,blower is not coming on
your blower motor failed and you need to replace it
Aug 20, 2009 | 1990 Mercedes-Benz 190
I HEAR A LOUD WHINNING NOISE FROM UNDER THE HOOD
Yes there is a bearing in the AC clutch assembly, and the bearing can be changed with out swapping out for a whole new AC compressor unit or even taking the unit out.
The other thing to you may want to check is the Serpentine belt tensioner. The tensioner then to break apart and or when the clutch activate put's more pressure on the system and the idler pully bearing could alsy be the problem.
Spray some water on the fan belt whale the engine is running and see if the noise goes away and comes back as the water dry's. If the noise goes away then it's just a worn belt and need to be changed or you may want to do the quick fix and buy Fan belt dressing.
Good luck and hope this helps
Apr 09, 2009 | 2002 Chevrolet TrailBlazer
York mini split unit has power but will not come on stand-by.
york split ac indor unit no working .timer light is on . how to stope timer control light ?
Jan 12, 2009 | Frigidaire FAA065M7A Air Conditioner
Squeeling noise coming from AC, compressor is on, fan not turning
The squealing noise is coming from the compressor. This noise is common when the unit reaches extreamly high pressures. The pressure is most likely high because the fan is not running. Since you can spin the motor it could be that the motor has damaged windings. Leave the unit off until the repairs are made to ensure no further damage to the compressor. You will need a multi meter and some experience reading wiring diagrams to properly diagnose the system. You can perform an amp draw on the motor to see if it is in spec. You can measure the volts to the motor and see if they are in spec. Finally the contactor can be measured with the proper meter to see if it is working properly.
My suggestion is to have the Motor and capacitor both replaced. Also inspect the wiring in the condenser electrical compartment for any signs of damage or burning.
Jun 17, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
