Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Lost the controller for Pioneer rear projection TV
I lost the controller for the tv. My set has 3 settings, video, tv and laser disk, (you can how old the set is) the set is stuck on tv but my cable is set to video so I can't use the cable until i switch the set back to video. I pressed return button on the set and made matters worst. I bought a universal remote hoping to set the tv. back to video but no luck. how can i change the settings without a remote and what the heck does the return button do, everything was working until i pressed that.
  • Anonymous Mar 28, 2014
    DO not have a remote
  • 36 Answers
Try pressing the "Input" button the front of the set. That should allow you to change between the different inputs. The return button usually returns you to the previous channel you were watching - don't think it works for the input though. Also, depending on the model of the set you have, try downloading the PDF user or owners manual - it will tell you how to use the remote.
Posted on Aug 13, 2008
Picture has a problem lost a lot of the color
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 13, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
Akai PT5499hd that has suddenly lost color alignment
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 23, 2009 | Akai PTH5498 54" Rear Projection...
Pioneer SDT50W1 rear projection TV clicks off when switched on.
Hey dudes...even i hav had the same problem that too with the same model specified here..Its a problem actually concerned with the power circuit boards of the tv. Its best to get it checked by an authorized technician. For me I had to replace a transistor on one of the boards. But after that my tv came up with a new problem....the colours appear like rainbows! Could nyone xplain y dis is happening?
Feb 06, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Tv runs through vcr only. What can we do? Also need a manual. Where can we find one?
try to resolder the tuner first and see if that makes a difference , otherwise you may need to replace the tuner
does video inputs work ok?
Nov 07, 2008 | Pioneer SD-P5795W 57" Rear Projection...
Need to re-set my tv
if u whent into the setup mode. u may have put the tv in a video mode what u need to do is turn the set on hit the menu on the remote control and tell me what it says on the screen if it shows video 1 tru 4 inputs u need to chage the inputs in the setup untill u see a channel number channel 4 or 10 that way u know that u are in tuner mode and video mode i hope this helps marty
Aug 25, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Pro 510 no color
Hello sherylfaith,
You might be having problems with the Video IC, actually the section of the IC that controls color. I would first check to see if the color controls are working, I would also suggest checking the color presets and defaults. After trying these controls if the color can not be corrected then troubleshooting of the circuitry is needed for this I would suggest that you have a qualified TV technician look at the set and give you an estimate for repair.
I hope this helps,
Thank you,
Shuttle83
Jul 29, 2008 | Pioneer PRO-510HD 53" Rear Projection...
Rca rear projection hdtv lost color convergence
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2008 | RCA MM52110 52" Rear Projection HDTV-Ready...
Pioneer Pro-200 60" Rear Projection Color Adjustment
after market duplicate remotes are reasonably priced-search tv remotes on-line.
Sep 26, 2007 | Pioneer PRO-200 60" Rear Projection...
Need programing guide and codes for a Jensen 6-device Universal Remote (Jer622)
I have this remote...only Pioneer listings are as follows: TV: 1004,1006,1089 VCR/DVR: 2010,2055,2071 DVD: 3312,3311,3287,3286 To program (for example TV setting): Press and hold down TV while entering code i.e. 1-0-0-4 To manually cycle through all codes (example for TV): Press and hold TV while pressing and holding ON/OFF, after 3 seconds the on/off button light should come on and stay on - release all buttons. Turn your TV on and press ON/OFF once each 5 seconds until your TV turns off. When it turns off, you have the correct code - press the stop button. Good luck.
Jan 18, 2007 | Jensen 6-Device Universal Remote Control...
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
103 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
