Question about Canon PIXMA iP2000 InkJet Printer
Waste ink tank
How do i go about cleaning and or replacing waste ink tank absorber?
  • 4,041 Answers
TRY THIS
Reset ip2000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 13, 2010
It keeps getting ink on the rollers(black) and transferring this to the paper in lines from the rollers. I have tried scanning a blank piece of paper but still keeps printing lines from the roller
You ink absorber is full then you need to clean it,maybe you cannot see by looking outside but if you disassemble it you can see inside 2 or 3 absorber tank. You can wash it or replace it a new absorber ...
try to put a waste tank outside your printer, you can see the small hose inside that connected to the print head when it park, just add another hose and a plastic bottle to place outside you printer this will be your waste tank now, so when you head cleaning your printer a lot of ink are uses that goin to your waste tank, by doing that it's easy to dispose you waste ink
Sep 13, 2015 | Epson Stylus Multifunction Inkjet Printer/...
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
My canon printer 1p 1000 says the waste ink absorber is full contact service center
hi
you need to replace the absorber waste container. But to ensure you can work around this, do this first. Remove the square rubber at the end of the right side of your printer. Use cotton cloth absorb the waste ink. Clean and wipe the ink around area and place the absorber back into the tray.
Finally clean your print head by using dry cotton swab. If this deosnt work, try this: if it doesnt solve the issue, you must replace absorber waste ink tank .
  • You can manually override it, but I recommend getting it replaced.
    Reset waste ink tank counter CANON PIXMA iP 1000
    Disconnect printer from AC power
    Press and HOLD the POWER button, and connect printer to AC power
    release the the POWER button
    Press the POWER button again
please send me 4 thumbs up
Jul 20, 2011 | Office Equipment & Supplies
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
5) Select OK
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Absorber tank is full
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 01, 2009 | Canon Office Equipment & Supplies
Canon i550-turn on-orange/green 8x then long green
From the Canon website:
Solution: Ink Absorber Replacement Options i550
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
For the Waste Tank Reset Code, and how to repair or replace the Waste Tank, see this website:
http://www.bioscomputers.ca/CanonWasteTankCodes.htm
Jul 16, 2009 | Canon BubbleJet i550 InkJet Printer
If ink absorber is already full what should i do next?
it is not possible for you it is the problem mantainence wast tank full it mean when we print then chack cartridge is automacily clean then some ink fall under pad this pad is full ink then machine say ink absorber tank is full
you go to aservice centre only support printer canon. Thy clean wast tank and reset your printer
Jul 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Pixma Ip90v waste ink tank full
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
You have to send it to your nearest service centre.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Dec 16, 2008 | Canon PIXMA iP90v Printer
Ink waste Absorber
you are correct about the waste ink tank,did you check the pipe (if any)which use to carry the ink to waste tank,if it is clogged than also the problem will arise.
Mar 31, 2008 | Canon PIXMA iP2000 InkJet Printer
Canon iP2000 Waste Ink Absorber - where is it for washing and replacing?
I found it under my ink cartridges in my Canon iP2000 printer. Trying to losten it for cleaning, it came out in my hand, I washed it and replaced it with a tiny amount of glue. After resetting the program, it is working again.
Feb 11, 2008 | Canon PIXMA iP2000 InkJet Printer
Canon PIXMA iP2000 InkJet Printer Logo
63 people viewed this question
old marine
old marine
