Question about Frigidaire FRT17G4B Top Freezer Refrigerator
MAGIC CHEF.. MOD MCBR1000W
HI, MFG DATE 3/04.. WONT COOL.. RUNS, FAN RUNS FINE BUT WONT COOL AT ALL.. NO ICE. ANY HELP WOULD BE APPRECIATED.. THANKS FRAN
Try to replace connector for defrost heater it is loose and does not have good connection. It may work for a while and then is loosing connection. But check the defrost heater if is in good condition.
I hope it will work.
Posted on May 12, 2009
Please gime an ansuer
thansk
Posted on Sep 16, 2008
We have the same fridge/freezer - a repairman came out to fix it and said the heater needed to be repositioned.. within a week the back was full of ice again, the repairman came back and said the defrost thermostat needed to be replaced.
Posted on Sep 05, 2008
Magic chef mcbr1000w
Do you see any ice buildup in the freezer?
Jul 06, 2013 | Refrigerators
MCO153UWT shutting down after 3.5 minutes
it is an internal fan that is the problems, if this is a counter top MW just replace it. if Over The Range (OTR) and under warranty call for service. if out of warranty replace.
Jan 23, 2012 | Magic Chef Microwave Ovens
Magic Chef Defrost problem - need defrost heater
did you read out the heater to make sure it's bad,do you have power coming to the heater
Nov 08, 2009 | Refrigerators
Magic chef refrig model # MCBR1000W defrost thermostat
RepairClinic.com is a fantastic online site for ordering appliance parts.
Jul 29, 2009 | Magic Chef CTB1821AR Top Freezer...
Bottom of refrigerator not getting cold enough, freezer is working fine, - Magic Chef -model MCBR1000w
have you cleaned out the coils underneath the fridge? it's very simple. pull the fridge out, look underneath(try pulling off the bottom grill from the front for more access), and start cleaning. to much dust and lint will hinder the coils from cooling. A vacuum with the brush attachment or little broom works good.
Jul 27, 2009 | Magic Chef Refrigerators
Magic Chef MCBR1000w stopped cooling
If the compressor runs on 120 volts AC, (some are three phase DC, you can use a 3n1 hard start kit, they are very simple to use and cost around $20 dollars, you can purchase them at HVAC supply stores. If the compressor continues to short cycle after installing the hard start kit, then you need the compressor replaced and should check your warranty, this is often an expensive repair.
Jun 15, 2009 | Magic Chef CTB1821AR Top Freezer...
Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Aug 27, 2008 | Magic Chef Refrigerators
Our Magic Chef fridge model # MCBR1000W does not seem to be keeping the fridge part cool enough, but still keeps the items in the freezer section frozen. The compressor is working, so not sure why this is...
yes the freezer door not closing properly will effect the refrigerator. also check in the freezer back wall and bottom for any frost buildup. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Magic Chef Refrigerators
Why did I buy it Magic Chef problem
of course replace the fan some times they go bad some times defective it happens seen them bad brand new out of the box
Feb 16, 2008 | Refrigerators
MAGIC CHEF MCBR1000W
Had trouble finding a diagram with this model # but most common defrost problems are bad defrost thermostat, timer/control board, or a little more rare is the defrost heater.
Oct 06, 2007 | Frigidaire FRT17G4B Top Freezer...
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
371 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
