Question about Black & Decker String Trimmer Cordless 12" 18V
Trimmer feed the string won't feed any more
    Problem Solver:
  • 9 Answers
Try trimmer manuals. the spool is probley wond backword .
Posted on Jul 30, 2008
When I had this problem I replaced that ratchet toggle part that the string drum sits over. Do you use replacement refills or do you refill them yourself. If you wind the string in the wrong direction it all affect the auto feed.
Jul 15, 2014 | Black and Decker USA BLACK & DECKER...
How to feed trimmer line on y25 yard trimmer gas
Depending on what type of string head you have. If it's a "tap and go" style head, just rev it up full throttle and tap it on the ground. It should feed the string out and the blade on the shield will cut off the string to the correct length.
Sep 22, 2012 | Yard Machines Gas String Trimmer Y25
I properly replaced the line spool but it won't feed automatically.
After you replaced your string in the trimmer and fed it through the hole in the plastic casing in which the spool fits into, did you pull the string until you hear a click? The click locks the string in, then you can bump and feed as usual. Otherwise it won't feed normally.
Aug 13, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
String on weed wacker does not automatically advance.
the notice on the trimmer says it has an AFS Automatic Feed Spool, "NO BUMPING REQUIRED". I see that underneath the spool, there's a small plastic centrifugal weightwith a peg on it. . It kinda looks like it might advance the line each time the electric motor starts and stops. If there are loose clippings in there, or if the weight is stuck, it probably would cause the problem.
Apr 21, 2010 | Black & Decker String Trimmer Cordless 12"...
B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Apr 21, 2010 | Black & Decker 14" Grass Hog Xp...
String will not feed when bumped
I've never had any luck with those stupid bump heads. Every time I would refill them, the string would get caught up. They bind up. I finally replaced the bump head with a string head that you place short pieces of string in. They're not perfect either. You have to pre-cut the string to about 9-12 inches in length, and just replace the piece when it's time.
Jun 28, 2009 | Troy Bilt Tb70ss Gas Trimmer
Only 1 string trimmer /// string keeps feeding when running
You have the string wound the wrong way on the spool.
Jun 17, 2009 | Black & Decker 14" Grass Hog Xp...
One side feeds to much string the and it keepsgetting wrapped around, the other side does not feed the string out?
You have wound that string in the wrong direction. Both sections of string should be wound in the same direction. If you need further assistance, just let me know.
Jun 06, 2009 | Black & Decker 14" Grass Hog Xp...
Change feed fuel feed line craftsman string trimmer
no should be fairly straight forward! you can find the tubing at ace lowes home depot! good luck & happy trimming!!
May 31, 2009 | Craftsman 25cc Gas Line Trimmer
Black & Decker String Trimmer Cordless 12" 18V Logo
158 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
