Question about Philips 42PFP5332D 42 in. Plasma Television
42" Philips plasma screen goes black
My Philips 42" plasma tv screen often goes black, sometimes only the bottom half. When I tap the side of the set, the full picture returns but the problem returns...... any advice/suggestions? I bought this tv in april 2008. Today is July 24, 2008. I was watching tv, when the screen started to slowly go black. As if, black curtains were being coming towards the middle from all four sides of the screen. While the black was closing out the screen, a loud buzz was the prominent sound being heard. I tuirned off the tv for a minute. After turning back in, I saw the black engulf the rest of the screen. At this time only seeing black. Audio going, yet, the loud buzz was still the dominating sound. I turned off, unplugged for a half hour. Returned with the same result??????
  • 1 more comment
  • r_tressler Dec 10, 2008
    When we turn on the tv the sound is there but no picture. We have turned it on and off several times but no change. Help the Tv is only 1yr old.
  • Anonymous Mar 18, 2014
    one time restarting the TV solved the problem, but not today
  • Anonymous Apr 01, 2014
    When I turn tv on the screen is black. Sound is heard. Cannot see anything at all. Have unplugged and plugged back in. No change.
  • 52 Answers
You need to replace y-sustain board.
Posted on Jul 25, 2008
My LG 42 Plasma works sometimes then half the screen goes black but the right side stays perfect???
have almost the same problem left side is black with sometime blue line red lines or a whole bunch of different lines some one help please have sound and right side of tv works fine
Sep 26, 2010 | LG 42PC3D 42 in. Plasma Television
While watching tv half the screen goes black
Download software from the Phillips web site. Use a usb flashdrive to transfer the download to the TV. This worked well for us and our picture is better than ever.
Apr 09, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Picture goes black on bottom half of the screen
You have a bad connection to the panel or bad caps on the boards. Not something for the DIY'er. High voltages in plasma sets.
Mar 31, 2010 | Sanyo DP42746 42 in. Plasma Television
My plasma screen goes black on bottom 1/2 of the screen
In most cases the lower Y-Buffer board causes this issue. Unless you know how to work on a TV it is suggested that you have a technician look at the TV and repair it for you.
Nov 05, 2009 | Philips Magnavox 42MF521D/37 Television
Bottom half of screen is black
its ur diaplay problem.. go for a change of new display...
Jun 30, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Aug 25, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Phillips 42 inch Plasma -Screen Issues!!!
intermittent loss of picture on either bottom or top half of screen is specific to y buffer boards located on left side of screen going from top to bottom when looking at back of tv. the y lower buffer would be the board to replace to resolve the loss of bottom half of picture. if the top half also is going out intermittently could tied to upper buffer as well but just a note the y main board to right of these buffers drives those two boards so in some cases could also be part of the problem. if only bottom half is affected i would recommend replacing lower buffer only
Aug 07, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Jun 03, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Samsung PS42S5hX - Bottom half of screen flashing black sometimes permanent, does not do this all the time.
might be y drive board bottom half it connects to the y sus board usually on the left side if your looking at the set with the back off
May 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Philips 42PFP5332D 42 in. Plasma Television Logo
2,419 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
