Question about KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator
Refridgerator not cooling
I have a Kitchen Aid that's less than 2 years old. It suddenly stopped cooling and the temp is now 82 and 40 in the freezer (and rising). I unplugged the unit for 5min but it's still not cooling.
Any ideas?
  • ewinche May 11, 2010
    About the white plastic vent and the phrase "You should be able to pop it off"
    I cannot get it off, popping or otherwise. I popped off the top vent cover in the main (top) compartment of the fridge. There was no cold air coming in to that fridge area. I think I should hear a fan but the appliance seems very quiet. Fridge temp is 70 degrees. Freezer seems OK.
I had the same problem with mine... if you look at the top back shelf there should be a white plastic vent. You should be able to pop it off and you will see a small door inside. This is where the cool air escapes to the top area of the fridge. It most likely that this door is in the shut position, which would explain why your fridge is so warm. For a temporary fix you should be able to prop this door open with a small piece of cardboard and you should notice your fridge beginning to cool again. If you want to fix this problem permanently you will need to order that part. It should be fairly easy to install... all you need is a screwdriver and about 15 minutes of time. Good luck!
Posted on Oct 25, 2008
Maytag refrigerator mtb2154drq suddenly the refrig stopped cooling but freezer still working. Even with high setting of 9, temp doesn't go below 60degF, while freezer ar 4-5setting is at 25degF. Up until...
The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 10, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
My kitchen aid (5 year old)fridge keeps quitting--no cooling.
Please change it Compressor because The pump of it compressor is not working properly
Apr 13, 2010 | KitchenAid Architect KBRA20ERSS Bottom...
Water stopped and freezer not cooling
you probably have a bad evap fan motor in the freezer compartment. when this motor goes bad it doesnt distribute the cold air around causin subfreezing temp in the bottom of the freezer it then migrates into the fresh food compartment. you can order the motor by the mod# of your refrig and it is fairly easy to change yourself. good luck peyton
Jan 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Not cooling/freezing THERMADOR SIDE BY SIDE REFRIDGERATOR BUILT IN
Sounds like thatyou refrigerator has leaked out the refrigerant. If you have a condenser i.e. cage on the back , place your hand over it and see if it is warm if it is not then if deffinaltey the gas.
this is not a diy job and you will need an engineer with relevant qualifications..
hope this helps
cheers wash doctor
Aug 25, 2008 | Refrigerators
Kitchen Aid Fridge problem
ok first the freezer does all the cooling for the whole unit and in order for it to cool properly the freezer needs to be a certain temp it should be around -10 -6 if its not reaching that temp it will still freeze and apper to be working right also check to hear if the freezer fan is running as it pulls air from the fridge and cools it then blowes it back look in the freezer on the back wall toward the bottom see if frost is building also in the refridgerator section on the left hand side of the cabnit is a return vent make sure its not blocked and see what the thermostat in the freezer is and let me know we need to know things like this to help narrow the promblems and people dont reply to the questions so we cant answer appliance repair is a skill
Jul 13, 2008 | Refrigerators
No cooling in refridgerator
is freezer cooling?
a possible cause is build up of ice on the evaporator. take off the back panel in the freezer and check. also check the fan is working. if there is excessive ice build up, this can mean that the defrost system is not working. in any case, if there is ice build-up, carefully melt the ice off with a hairdryer
Jun 19, 2008 | Samsung RB215LASH
Refridgerator isn't keeping cold
its in the freezer when you open yhe door the compressor is in the back take the cover off and see if trhe compressor is running
Apr 03, 2008 | Refrigerators
REfridgerator Failure
Refridgerator is 5 years old. Simply went out of cooling and freezing. Still makes operating sounds and lights work but losing our freezer full of food is disturbing on a refer only 5 years old.What could be wrong?
Mar 17, 2008 | Jenn-Air JCD2389G Side by Side...
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator Logo
191 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
