Question about Dell 922 All-In-One InkJet Printer
Left catridge is wrong
We soaked it and still reading that the cartridge is wrong
Had a similar problem and tech support, after going through all the fixes, stated that the cartridge is defective and needs to be replaced. Hope that this helps. Neil
Posted on Jul 30, 2008
Wrong cartridge showing on printer
I had same problem of wrong cartridge error on canon multipass 700. I read some of this site's remedies and tried them. First I realigned printer head , then I removed cartridges and cleaned the place where the cartridge sits at bottom with 1 alcohol soaked q-tip ( 1 for each color) and reinserted the cartridges again. Left the printer off for a few days. When I turned on printer , It warmed up and the wrong cartridge message was gone and I was able to print again. Wow! Thanks again for all your help.
Jul 07, 2010 | Canon MultiPASS MP700 All-In-One InkJet...
I put new printer cartridges in;left catridges lexmark x6570
maybe the cartridges you put are nt compatible to the printer or not properly place
Nov 29, 2009 | Lexmark X6570 InkJet Printer
I changed my black ink and now i get the message left cartridge incorrect..how do i fix it?
HP PSC 2210 InkJet Printer. The following has to be done for checking the Blank Ink Catridge working : 01. Remove the existing Black catridge and Color Catridges from the Printer carefully. 02. Clean the location with a soft cloth with cleaning liquid to make the place dust free. 03. Put the correct black and colour cartridges recommended by HP and that too genuine one. 04. Do not use any refilled or reinked local catridges that will spoil the HP PSC 2210 printer. 05. Re-install the catridges both Black and Colour properly. 06. Take a test print out - both black and colour print outs. 07. Check the Printer status and there is no warning of Cartridges wrongly inserted. Have a Good day.
Jul 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
Error states wrong cartridge even though i have replaced them
hi! there,on your previuos catridge it work properly,have you ever change the brand or the model no, of your catridge,the printer can detected if the catridge is not suitable to printer,there is a circuit printer head on catridge,not all catridge are useful to printer try to check the brand and model no, printer exactly,check this on manuals and try to purchased the same brand of printer,if still not work take this to cannon srvice center,have a nice day thank,s
Mar 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Cartridge
Remove both the Cartridges take a Paper Towel turn the catridges direction so that u can see a Copper plate with small boxes on it....... Just wipe it twice or thrice with the Paper Towel..........Now Move the Catridge carrier which holds the Catridges manually with ur Hand from right to the Left and from Left to right for about 20 Times............. Now Insert both the catridges inside the Printer............. Turn the Printer On............ If still the same Error Message.... Clear NV RAM..... Unplug the Power Supply from the Printer.... Press and Hold the #5 button on the Printer and plug in the Power Supply....... Don Release the #5 button till the Printer turns on completely.... After releasing the #5 button........ Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM..... Now as soon as the Printer is Restarted....... Still if it doesnt work call: 1-800-LEXMARK (539-6275)
Get the Printer Replaced... Good Luck
Jan 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
Blinking power light
It could be the timing of the cartridge is out possibly from the belt.
It should be serviced by a technician.
Jun 16, 2008 | HP Deskjet 3845 InkJet Printer
Lexmark 3470, new ink dosn't work.
In this case as u said u used this Catridges in 2 printers then check if u have removed the Transparent Strip from the catridges mand if it is removed and still u face this problem make sure u have inserted the Catridges in the right slot........ U need to insert the colour catridge on the right side and the black catridge should go on the left side.... If no go get the catridges replaced....... Good Luck.......
Apr 06, 2008 | Lexmark X7350 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
20 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
