Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Vacuum my vaccum is not sucking
I just discovered that if you remove the dust cup, lay the vaccum back, reach up inside above the dust cup area, there is a yellow piece that can be removed (twist it and it comes out.) I found that there were GOBS of lint and pet hair stuck inside there. We removed all of that and the vacuum works great again!
Posted on May 21, 2009
  • 281 Answers
Disconnect the hose from the base and turn it on see.if you have suction which i'm sure you will clean all the filters there are three.one above the dirt cup,one up inside above the dirt cup and one below the dirt cup that says hepa the door swings open.blow through the hose and see if its clogged.on the base where you disconnected the hose see if there is anything in there.if there is you can bend the tip of a coat hanger til the tip is round and work it down into the tube where the hose connects.if theres anything in there you should be able to push it out through the bottom with the hanger clean filters after every coule of uses
Posted on Apr 23, 2009
Why won't my shark navigator cordless vacuum pick anything up?
Sometimes everything seems to be fine. The brushes turn, but if the brushes aren't cleaned of hair, rug tangles and so on, the brushes on the vaccum get filled and it won't puck up anything. ON THE OTHER HAND if the brushes are clean, did you check all your hoses from thr base of of vaccum where things get sucked up to the bin?
Jan 27, 2016 | Shark Vacuums
My Volta vaccum is sucking strongly using tools but not when using floor vaccum
what blocks the suction hose when not in use . our dyson has a slide plate at end of hose
Feb 14, 2015 | Vacuums
I think that I accidentally sucked up a child's
if you have a shop vac you can try blowing it out. for some reason this works better. You also might try a coat hanger with a U bend at the end.
Aug 09, 2011 | Electrolux EL6988E Bagged Canister Vacuum
Ridgid shop vac is not sucking
Check the intake hose for a blockage. Attach the hose to the exhaust outlet and turn the vacuum on. If no extracted air is blowing out of it the hose is totally clogged up
Apr 10, 2010 | Ridgid 25648 Wet/Dry Vacuum
Sounds like I sucked something up
recommend dyson service. it sounds like a broken drive / stripped gear etc.
Jun 12, 2009 | Dyson DC14 All floors Bagless Upright...
My Bissel Vaccum cleaner is making strange noise!!
call the 1-800 number on the back
Jun 11, 2009 | Vacuums
The vaccum turns on but the brushes dont spin, and i have hit the reset button on it already...
vacuum turns on and sucks but the brush does not spin and I have pushed the reset button
Mar 20, 2009 | Dyson Slim DC18 All Floors HEPA Bagless...
The unit has 2 intakes. one is used. what do i do with the other
no one is exaust so one sucks one blows sucks is inside for vac . blows gets exsausted outside
Thank you for useing fixya please rate me
Oct 27, 2008 | Hoover L2310 GUV Central System Vacuum
Help!!!!
it's likely wrapped around the brush
pull out the roller and un tangle it
Aug 12, 2008 | Dirt Devil M084600 Dynamite Bagless...
Vaccum has no suction
Here is what we did to fix the problem of our vacuum having no suction.
We unscrewed the three screws on the back and took the hose off of the vacuum.  Then we took the hose outside and put the water hose through the vacuum hose and turned on the water.  After about 30 second the water pushed through a dust bunny the size of a fist and a marker.  Basically, the vacuum did not have suction because the hose was clogged with dust, etc.  After reassembling the vacuum, it worked just fine.
May 11, 2008 | Kenmore 34923 / 34925 Progressive Bagged...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
541 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
Roger Potts
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
