Question about Philips Magnavox 55P9271 55" Rear Projection Television
I need some help
Can u help me with my 46 inch big screen tv vi need to now what is wrong with it
  • 4 more comments
  • wolverines01 Jul 25, 2008
    do not know the modle number or the set it has non both be removed man somebody told me that the reason was that i got the dip at the top of the tv and the dip at the bottom and the blurrying of the tv and word is because of the ic failure is that true or not man
    but i do not know the model number so that were im stuck at plus i do not know what part i need yet unless u know or do u got a diagram of the tv to some me what i need so i can look for it
    i looked i order stk392110 and ther were not the right one we found that out she said the i need a ic amp
    this is what she said maybe you know something more
    Ok that chassis is from 1987 thats a classic. That is going to have one large Ic a STK number that powers the convergence unit, and that board way over to the right attached to the side of the set has all the heat sinks on it? The transistors on those heat sinks control the individual movements of the convergence controls. So your main IC amp is whats needed. Can you give me the number off that large IC with a STK number on it?
    the model number is fp5240 w101
    ye with think we got the right part order now we hope
  • Philips Master
  • 8,617 Answers
Certainly, I can help you out what is the set doing and what is the model number of the set? Please reply to this same post when replying.
Posted on Jul 25, 2008
  • 2 more comments
  • Sonny Berry
    Sonny Berry Jul 25, 2008
    Thats usually the case of a failed convergence IC when you get the arcs at the top and bottom of the screen
  • Sonny Berry
    without the model number there is no way to tell unless you take the number off the ICs . If its a HDTV its a DPTV chassis with two STK392-120 ICs if its a non HDTV it has two STK392-110 ICs. If it has only one those are from the 70 and 80s so they had different ICs they used so you will need the number off that IC to tell.
  • Sonny Berry
    Thats an old chassis that one uses one single IC then about 10 other transistors on a seperate convergence board. I am not sure of the part numbers as that has to be in the PTV 6 or 700 series rear projections that was before they started using two ICs to bypass all the single transistors.
  • Sonny Berry
    Ok if you need any more help let me know
OUr 46 inch Big screen tv have just started making whistling noise. turn off and back on and it starts back up.
Sounds like the horizontal coil. or possibly the flyback You can get replacements from www.tvrepairworld.com they will also help you determine which components is most likely causing the issue.
Dec 29, 2009 | RCA HD52W59 HDTV Projection Television
I bought a brand new 42 inch plasma vi vo tv 2
New products do fail. The set should certainly be under warranty. I would speak to the dealer you purchased the unit from and see what they suggest. Don't remove the rear cover, or do anything else to give anyone a reason to void your warranty. Most brands are 90 days on parts and labor.
Nov 25, 2009 | Televison & Video
RCA BIG SCREEN TV WONT TURN ON HELP !!!!!!!!!!!!
Try unplugging it for about 30-60 seconds, then plug it back in and before you turn it on, make sure there is a good video source going to the TV either from Satellite/Cable or a DVD player or something.
If this doesn't work, try unplugging it a bit longer and then plug it back in and try again. If it still does not work, you may have to take it in and get it serviced.
Usually when devices power themselves off like that, there's something wrong...
I hope this helps :) Good luck!
Best Regards,
James
Jul 21, 2009 | RCA L46WD250 46 in. LCD HDTV
Picture in wrong position, too big for screen
Hi
maybe the system settings is not set in default mode
Thanks!
Mar 05, 2009 | JVC AV27F476 27" TV
Old magnavox 52 inch big screen tv - screen rolls, jumps, loses c
the screen on my hdtv has alot of marks on it how do i get another
Feb 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Power makes a sound but does not power up
SAME PROBLEM AS YOU ROBERT! Same TV and same problem after pluggin in something else in another outlet. Did you ever solve this issue?
Please e-mail me at yanalou at aol dot com.
Big Screen Blues II
LOU
Dec 02, 2008 | Hitachi 46F510 46" Projection HDTV
Won't turn on
tv chassis ctc 195 , hvt transformer, digital conv, power supply,
Dec 04, 2007 | RCA P46921 46" Rear Projection Television
Hitachi 46 inch projector tv
Lenticular and/or fresnel screen in backwards!
Oct 09, 2007 | Televison & Video
Color on my big screen tv
sounds like you need to have the two convergence IC's replaced. These are soldered on the main board. Good Luck
Jul 16, 2007 | Philips 46PP9302 46" Rear Projection...
Philips Magnavox 55P9271 55" Rear Projection Television Logo
46 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
