Is the time and date correct on your computer? These certificates are dated and if your computer is out of that date range, you will get a certificate error.
Hi, please check if the date and time of your computer is correct, if not then correct it then close and reopen your internet explorer. let me know if that works.
fix time and date ...it might not be ok ..and it sees that the certificate you are running it not in use until some time after ...and this might cause it ...if it is not this ...uninstall the explorer 7 ...it will roll back automatically on explorer 6 ...and all will be ok ... so go to ..c panel ...add/remove programs....click on explorer and click remove ...follow the instructions...if you really want it ...you can reinstall it from the net ...and any errors will be gone..
Mr. Vidya the problem mentioned by you can be solved by resetting your browser. To reset the internet explorer follow these steps:
1>click on start
2> select run
3>In the run box type -> inetcpl.cpl
4>You will get the internet properties window
5> select programmes tab and click on reset
6>select advanced tab and click on restore defaults
when u see that error clik on it and view certifacate then u can install from there its very easy then close interent explorer and open again then it not need certificates.
