Question about Duracraft DB101 Floor / Box Fan
Duracraft Commercial grade portable Fan
When I turn it on all it does is hum. Is it fixable??
2 Suggested Answers
  • 43501 Answers
SOURCE: My Duracraft Model DV-519 Commercial
Check to see if the fan has a capacitor on the motor...
Often when you get a hum and no spin it is because of a bad cap.
Also check that the fan spins freely, it may need some oil...
If it does need oil, first work in some WD-40 and then some light small motor oil at each end of the motor...
Posted on Aug 19, 2010
Hi, I have a Duracraft commercial model fan high velocity I need motor DM514
did you check already the thermal fuse and capacitor??
Oct 02, 2015 | Duracraft Dryers
I own a Duracraft commercial grade high velocity fan, model DV-518. When I turned it on, the blades started to turn. Then there was a loud click and a small smell. I quickly turned the switch off. When...
Hi, I had the same pop noise and turned off immediately. So my question is, where is the capacitor, in the switch assembly or inside the motor?
Aug 30, 2013 | Duracraft Dryers
DS 1910
Hey Anon,
You will probably spend more on trying to fix this than just BUYING A NEW ONE!!!!
Jun 19, 2017 | Duracraft Dryers
Duracraft Fan Stand is broken need base adopter
depending on the year you may not be able to find parts because walmart does not make things like that anymore
Dec 26, 2011 | Duracraft Dryers
Hi, we have a Duracraft Commercial Grade High Velocity fan. When we turn it on it just hums, fixable? thanks, Nancy
Mine does the same when I try to start it on low. If I start it on hi after it gets going I then can turn it to low and works great. Hope this helps.Also you need to take it apart once a year , remove blades, take it outside and air blow the motor out .
Sep 01, 2011 | Duracraft DS-1600 Fan
Hi, I have a Duracraft commercial model fan it sits on a metal stand about four ft high with a round base. The on/off switch is housed in a black box screwed to the fan base and then a wire runs up into...
A short circuit in the power wiring would probably cause the fuse or breaker controlling the circuit to open. Make sure the AC outlet you're plugged in to is actually working. If so, there's an open circuit somewhere if no power is reaching the motor.
Have you checked the switch with an ohmmeter to make sure it's really working? Check the wiring from the switch to the motor. You can also make sure the motor windings aren't open with the ohmmeter. The motor may have burned out as they sometimes do.
Check for voltage right at the motor. If this is a brush-type motor, the brushes may be worn out. It may also be that the motor is getting voltage but has a bad starting capacitor. Most commercial equipment uses capacitor-start motors, and the capacitor is usually mounted in a bracket on the motor. You can test the cap with a meter that has capacitor checking; replace the cap if it measures outside of the tolerance marked.
Aug 07, 2011 | Duracraft DS-1600 Fan
Our duracraft portable fan is humming and not moving? what is the problem and can it be fixed?
Sounds like the armature needs to be cleaned. Dirt can build up on the ends of the motor shaft that operates the fan and where it is held in place, the dirt can actually stop the fan. I would spray both ends of the motor shaft with WD40 and rotate the fan by hand until it is free. This is the cheapest thing to do in order to try and get the fan running again. The problem may be worse than this, but it is a good place to start.
Sep 06, 2010 | Duracraft DB101 Floor / Box Fan
I received a Duracraft model CZ-600 oil Heater. I don't know
I'm in the same boat..are we the only ones who have one?
Nov 22, 2009 | Duracraft DY-012 Tower Fan
Replacement Blade Knob for Duracraft Table Fan Model No.DFT-218W
I thought the same thing. It was hiding in one of the stryfoam pieces.
May 01, 2009 | Duracraft DFT-218W Table Fan
Duracraft DB101 Floor / Box Fan Logo
641 people viewed this question
Top Duracraft Dryers Experts
Bonard Allen
Are you a Duracraft Dryer Expert? Answer questions, earn points and help others
