Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Hitachi 50v500a high definition tv
Everything is green on screen. tried adjusting color, removed all green color, adjusted contrast but nothing seems to work the picture is still mostly green
  • LARRY3RD Jul 28, 2008
  • Anonymous Mar 19, 2014
    the clarity of the picture and the colors need to be adjusted
  • 11 Answers
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
Posted on Aug 31, 2008
  • 3 Answers
Posted on Aug 26, 2008
    Problem Solver:
  • 5 Answers
About two years ago, I had a small red blur in the middle of the screen. That red blur is now all over my screen. I called Hitachi and they said that there's nothing they can do about it because it's almost 4 years old and the warranty has expired. I called a repair shop and they said that it may be a light engine problem and it will cost about $1300 to repair. Might as well get a new TV for that. I did some research and found out that this is a common problem and that you need to be persisting when calling Hitachi and speak to a supervisor. The supervisor said that if a repair person confirms that it's a light engine problem, that they will send the part FREE OF CHARGE (just gotta pay for labor). They will only send a replacement once.
Green tint
Go to a channel that is in black and white and turn color all the way off.
Screen should be a black and white or gray color.
If green there is a fairly easy way to adjust--let me know what you find and I will tell you how to attempt the adjustments.
Feb 18, 2012 | Hitachi 57S700 57" Rear Projection HDTV
Colors are off on the TV. When I try to adjust the contrast and brightness, etc from the menu, either everything is orange or green or yellow.
Contrast and brightness won't fix it.You are on the right path though.You need to search around for a color adjustment.You should have numbered scales for all 3 primary colors to adjust.It should also be somewhere under the picture option.Let me know if you need better instructions.Good luck!
Aug 05, 2010 | Toshiba 42AV500U 42 in. LCD HDTV
This is an LCD rear screen projection TV. There is a Red, Green and Blue LCD pallet that is mounted on what they call an X-cube. If all you are getting is Red and green then something happened to the blue pallet. Either the Ribbon connector came off or is loose or something worse. How hard did you mover it?
Another thought. How is it hooked up. If component then this may be the issue as component video connections are Red, Green and Blue. Just a thought.
Let me know.
Blessings always,
A/V Media Tech Guy
Nov 30, 2009 | Televison & Video
Hitachi 50v500a HD picture not as sharp as it used to be
When was the last time you changed the lamp? If its the origional its over due.
Oct 01, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Digital array
that is for adjusting the colors center , you should not use this unless the colors seem off center and then you may make it worse if you do not know what you are doing , this is really for a tech to do adjustments
Aug 18, 2008 | Hitachi 50UX57B 50" Rear Projection...
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Hitachi 43fdx01b rear proj. hdtv
if you are using Y, Pb,Pr, connection to the tv from a sat or cable box check the red wire on both ends red may be disconected.
Feb 09, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
1,526 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
