Question about Samsung Televison & Video
  • Enrique Madrigal Jul 27, 2008
    The problem was solved! I change the photocoupler PC123 and EUREKA! the tv is working!
    Thanks for the help staticfree.
  • 3 Answers
Internal fuse, small 2 amp slow blow, check both, some times white coated inside when blows turns brown in middle, voltage spike problem
Posted on Jul 25, 2008
Lightening caused surge protector to "spark" but no power loss, and everything plugged in works except the Samsung HDTV
Hi, In a lighting storm you are supposed to unplug your TV. In this case you may have fried something on main board. Take it to repairman. Good luck.
Aug 07, 2014 | Samsung Televison & Video
Polaroid TLA-01511C stopped working after electrical storm. Will try to change fuse, if I can get to it. How do I access the fuse? NOT equipped mentally or with tools to do more.
Contact any service technician. The fuse can be located at itw main power regulator board inside. If the power supply regulator board is found faulty, it will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
Aug 07, 2014 | Polaroid TLA-01511C 15 in. LCD Television
Why won't TV STAY on?
Fault with the main power supply regulator board.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit.Contact any service technician.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
Aug 02, 2014 | Panasonic CT-32HX42 32" TV
My panasonic tau ct-34wx52 tv shut off by itself, now only clicks
Its power supply regulator section circuits need to to be troubleshooted.
Apr 26, 2012 | Televison & Video
No power on Samsung TV after storm
Hello Zkarim,
I'm very sorry to hear about your unfortunate new's. I had the same problem in my own home maybe a week ago.
Basically if your power flickered on and off at anytime during this storm then there was a power surge that probably fried your TV.
* First check the power where the tv was plugged in. Is it a power strip or a surge protector ? Surge protectors typically have an on/off switch and a separate reset push button.
If it is a power strip then the tv fried because there was nothing to stop it from happening (not even the fuse). If it was plugged into a surge protector then it could be quiet a few years old and not as reliable or the surge was to powerful for the limit on the surge protector.
The only thing you can do personally is send it in for repair if it's under warranty, if it is not then you can have it looked at by an authorized repair technician in your area. Troubleshooting should be fairly low, and you will at least be able to find out your options once they find the defected part.
Thank you for choosing Fixya!
Jul 15, 2009 | Samsung LE32A457 32 in. LCD TV
The TV will not turn on
transister on tube blew out, needs new tube, could be from storm
Jul 01, 2009 | Panasonic CT-30WC14 30" TV
Panasonic CT-32g19j
check The B+ of your tv. If no b+ Check the input AC voltage. If Ac i/p are ok but no B+ Volt maybe your IC in power supply has problem.
Jun 01, 2009 | Panasonic CT-32SL14 32" TV
Main power supply
If you changed the regulator and it still doesn't put out B+ you must have an open circuit somewhere. That model is known to have a 6.3 amp B+ fuse that opens and you must check it with an ohmmeter to tell if it's bad. replace it with a 7 amp fuse and you should be ok. If that doesn't solve it you may consider taking it to a shop. By the way, you're welcome for the tip. Two out of a hundred people said thanks for my time. Russmann
Dec 05, 2008 | Panasonic CT-32HXC43 32" TV
After power outage, tv doesn't turn on
First, the blinking light is a code, how many blinks? Second, regulators are not resettable. Don
Aug 17, 2007 | Panasonic CT-36HL43 36" TV
My samsung model- HCN4226W T.V will not turn on
You should always have all expensive electronics on a surge protector. It sounds like for this set the power regulators blown out as I know this set very well and seen it a hundred times!! its a power regulator IC that cant handle a power surge at all. and if thats your only problem, it shouldnt cost more then 175.00 to 250.00 to repair. Now with a surge though there could be other problems as well but from what you stated Im guessing alls ok except what i stated. Now Please do not attempt to repair yoursels, as these sets have alot of Hi voltage inside them even when they are unplugged.. Good Luck
Jun 28, 2006 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
85 people viewed this question
Jerry Greenberg
Jerry Greenberg
