Question about Konica Minolta PagePro 1350W Laser Printer
Won't pick up next sheet of paper
I have a 1350W that no longer can pick up the next piece of paper from the pile. I end up having to manually peel up the next sheet and gently push it into the printer for the autofeed to grab it. makes printing any larger job a real hassle. Any thoughts?
  • lunalinnea Aug 17, 2008
    I am having the same problem.
  • A440 Sep 02, 2008
    I have the same exact problem, and I also hand-feed the next sheet. I had some success by keeping the paper tray full, but it still malfunctions way too often. (and a note: a simple opening and closing of the toner access door resets the printer - you don't need to power off/on)
    I actually found this website while searching for a fix to this problem.
Clean the rubber roller in the middle with Formula 409.
If this doesn't help the roller will need to be replaced:
Part number 4136 3001 01 from 800 972 6705.
Posted on Aug 19, 2008
Didn't work for me
Posted on Aug 18, 2008
Wow! That really worked...I was facing just this problem and thanks to your webpage, was able to fix the issue within ten minutes. I appreciate the tip!
Posted on Aug 14, 2008
Use some Q-Tips and alcohol to clean the rubber rollers just above your paper stack - they get dusty and sometimes won't take the next piece of paper.
Posted on Aug 06, 2008
Lexmark X4550 all-in-one Paper feeds only half way then jams
Frances;
I'm not Lexmark certified; however, paper motion fails are generic in nature. Paper motion fail can be a bit difficult to diagnose at a distance...
* If it jams at every sheet then check to insure there is not a bit-o-paper stuck from a previous jam.
* If it has been an issue that has been increasingly getting worse than I'd replace the pick-up roller(s)
* Lexmark's support page for your printer is below. (You can also find a service prover too)
* Parts order for your printer is also below. You can determine at the support page if your comfortable replacing pick-up rollers in that model printer.
support lexmark com Service Parts
Note:
* Frequently people tear a jammed sheet when it comes out leaving pieces behind. BAD! When you get a torn sheet in your printer insure you retrieve all the pieces. Those left behind guarantee a jam on your next try.
* Paper jams not caused by debris in the path or worn pick-up roller(s) is beyond user maintenance.
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
My Brother MFC-7820N has trouble picking up sheets of paper
Hi! I just recently noticed that the 7820N has an "extension" piece at the back of the paper tray. This extension should be pulled all the way out and the blue paper stop adjusted accordingly. Otherwise, the loose extension piece will slide out from the rear of the printer when the tray is slammed in, and the paper will not be where the the printer expects it to be.
Other than that, check that the pad at the front of the tray is clean, and that the plastic small roller next to it rotates freely. Also, try cleaning the rubber rollers that are located inside the printer above the tray with a damp cloth.
Apr 02, 2010 | Brother MFC 7420 All-In-One Laser Printer
PagePro 1350W won't pick up paper
Clean the rubber roller that draws the paper in with isoproply alcohol, in future, blow dust off top sheet in paper stack before printing.
May 19, 2009 | Konica Minolta PagePro 1350W Laser Printer
Pagepro 1350 will not feed paper
I have the same printer and had the same problem.
Cleaned takeup roller wit isopropyl and it has worked now for 18 months. If you dont use it often, remove top sheet from stack and blow the dust off it before printing.
Nov 14, 2008 | Konica Minolta PagePro 1350W Laser Printer
Won't pick up the next sheet of paper
While it doesn't always work, this problem seems to be helped by keeping the tray as full as possible. It has more trouble picking up pages when the stack is low.
Aug 04, 2008 | Konica Minolta PagePro 1350W Laser Printer
Konica 1350w will not pick -up paper any more? please help?
I had the same problem. I noticed there is a ridged rubber wheel that picks up the paper and it was just sliding over the paper. I opened the printer, pulled the toner cartridge out and rubbed the wheel with my finger until I could feel friction. Closed it back up and it works. Perhaps the rubber wheel gets coated with paper fiber and makes it less "sticky" over time. A simple cleaning may be all it needs.
Jul 27, 2008 | Konica Minolta PagePro 1350W Laser Printer
MINOLTA PAGE PRO 1250W AND 1350W
Clean rubber roller that picks up paper with isopropyl alcohol. I future, blow the dist off top sheet in stack before printing.
Feb 08, 2008 | Minolta PagePro 1350WN Laser Printer
Paper feeding.
Careful 'knocking up' and 'riffling' the sheets before placing in the feed tray will go a long way to to alleviate this one. Getting air between the sheets is the object of the exercise . The cutting packing and wrapping of sheets compresses them. Did you know also that there is a right side and wrong side to copy paper? Look at the side or end of a new pack for the arrow.
Aug 21, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Konica Minolta PagePro 1350W Laser Printer Logo
107 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
