PDAs
Problem for PDAs
Generic problem for all PDAs
Archos av500 hard drive replacement
By slovesweez on Jul 25, 2008
archos av500 hard drive replacement
Same Problem
Dec 18, 2008
-   it says eror cannot read hardrive
-   zaireundjee
Best Solution
posted on Feb 27, 2009
Helpful)
dsgsadf
Rank: Apprentice
Rating: 83%, 3 votes
Downgrade firmware from 1.5.12 to 1.3.12 and then replace the hard drive, it should work. It does not work with firmware versions superior to 1.3.12. If you have 1.5.13 you can downgrade to 1.5.12 using the normal archos update procedure (yes, from 1.5.13 to 1.5.12 you can freely donwgrade using standard offical method). You can find 1.5.12 firmware on the official archos download page. If you need the 1.3.12 version (not available at archos website) it can be retrieved there: http://www.opendrivers.com/freedownload/232939/archos-av500-portable-dvr-firmware-1.3.12-download.html
Comments:
Feb 27, 2009
- Downgrading procedure from 1.5.12 to 1.3.12: 1) Make sure your Av500 has firmware v1.5.12 (Setup->System->Firmware vers. on the Gmini), if not, upgrade or downgrad normaly to 1.5.12.
2) Get the 1.3.12 update file, put it somewhere on your PC. You need to get it from archos web site: http://www.archos.com/support/download/firmware/av500/1.3.12/UPDATE_AV500.AOS
3) Copy the UPDATE_AV500.AOS file from this zip in the root folder (where there's Music Video System ...) of your Av500.
4) On your Av500, do 'Update firmware' with this file (in Setup->System).
5) You should see lot of green text then you should get back to the main menu, if not, try again from step 4)
6) Without shutting down the Av500, plug USB cable and copy 1.3.12 update from step 2) on your Av500 (overwrite the previous one), unplug USB cable.
7) On your Av500, do 'Update firmware' with this file (in Setup->System).
8) You have successfully downgraded to 1.3.12 ! :)
Feb 27, 2009
- This is the link to the DOWNGRADER that is the modified .AOS file that permit the downgrade (I forgot to link it): http://www.archopen.org/tiki-download_file.php?fileId=73
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for PDAs
Questions and Unsolved Problems for PDAs
Answer
I want a product similar to Palm m505 to store data only.
Answer
when i charge my sidekick 2 does it have a light that lights up?
Answer
the phone won't turn on, only a red light comes on and off
Answer
I installed a new printhead for my laserjet hp L7580. It keeps giving me the message that the ink is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PDAs:
Top PDA Experts
Rank: Guru Guru
Solutions: 554
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
