Run Expert personal roots using Windows 7 XP mode .check this link
If the program is installed but gives the error when you attempt
to run it try this: Right-click the icon you use to start the program
and select Properties, then click Find Target (this will open Windows
File Explorer with the program's executable file highlighted).
Right-click the executable file and select Properties, then the
Compatibility tab. Select "Run this program in compatibility mode"
selecting the Windows 98 option. Try running the program again.
If your problem happens while you're trying to install the
program, try using the Compatibility Wizard on the Setup file for the
program. The file may be called Setup.exe or something similar, and is
located on the Installation disc for the program.
To run the Program Compatibility Wizard: Click Start, Help,
Support, Fixing a Problem, Application and Software Problems. Under Fix a
Problem, click Getting Older Programs to Run on Windows XP and then
click the Program Compatibility Wizard link. Follow the instructions in
the wizard. The wizard will prompt you to test your program in different
modes and with various settings. You may need to repeat this process
until you find the correct Compatibility Mode combination.
