Celestial HD Digital Television Receiver DVB8800HD
I have just bought one of the above from our local dealer who said I could hook this up onto my ageing Panasonic (THE ONE) Television and have it work. After a few goes I think he may be wrong. Any ideas would be most helpful. Thanks, Alan
It appears that the default output is set to component video by the manufacturer.
connect it to a suitable TV and change the output to composite and you'll be able to use it.
Posted on Jul 27, 2008
I have a celestial HQMI HD DIG TV. A dog chewed up my remote. I bought a SANSAI U/R. Will this remote work with my TV? If so do you know the code for my old R/C.
There should have been an instruction booklet with your new U/R.
Look in the listings to find your Celestial HQMI HD DIG TV. The
booklet will tell you what to do next.
Aug 21, 2011 | Televison & Video
Hooking up from hd receiver to hdtv ready projection tv. what cables do I use? vga or rca component red, blue, green and sync white/black? My hd receiver has output of :hdmi, rca component, s-video ,...
This particular television puts you in a tough bind - you can use Component cables in AV-1, but you won't be able to get HD. Or you can use the Component cables in the right-most component slot (AV-4), but since your HD Receiver probably doesn't have V/H Sync connectors, you may get a rolling picture. Try the component cables in the right-most slot - if the picture doesn't roll, you're in business.
Once again, I doubt that your model # is a 60pp9202, since that model doesn't have a VGA or DVI slot. If the picture rolls after trying the above, you will need to purchase a HDMI-to-DVI-D cable and hook it up from the HDMI output of your HD receiver to the DVI slot (that looks like a VGA slot) on the back of your Philips or Magnavox.
-Tha Mp3 Doctor
-Tha Mp3 Doctor
Mar 07, 2009 | Philips 60PP9202 60" Rear Projection...
Is the HD52W59 HD ready or do you have to buy a seperate antenna?
if you are hooking it to a coaxial conection there are 2. try the digital coax input.
Jan 28, 2009 | RCA HD52W59 HDTV Projection Television
How to hook up everything!
I have similar equipment.
You should use an audio digital cable to connect the bluray to the Yamaha receiver and another digital audio cable to connect the HD box to the Yamaha receiver.
Hope this helps.
Dec 23, 2008 | Yamaha HTR-5650 Receiver
Celestial dvb8800hd
problem solved by looking past the inseparable remote control and indexing the channel button on the unit. Fiddling with remotes can be a real waste of time.
Sep 23, 2008 | GE DSR-2000E
Normally, there are 2 ways to hook these devices up. One is the component cable that has 3 colors, red white and yellow. these color codes match an aux. input on the TV (or vid1 or vid2) You need to change the TV input to whichever you used by the remote or maybe under Ch2 (4,3,2,vid2, vid1, aux,111,110,etc) The other way is to use the round 4-5 pin S-video instead of the yellow jack, that is self explanetory. The 3rd way and this depends on your TV and receiver is to use the HDMI, composite or DVI cable connection. These are only for Hi def players and will be either a large multi-pinned computer type plug, 5 colored/lead "octopus" cable, or a smaller D shaped high density cable with the row of contacts inside the plug. In any case you need to tell the TV which input you are using.
Once you get the TV to show a picture of the receiver, then you autoprogram the receiver with the remote under setup or other menu.
Jul 24, 2008 | Televison & Video
Distorted HD picture when using Onkyo 605 receiver
use a hdmi switcher and the signal will be spilit up evenly between the two
Jan 02, 2008 | Onkyo TX-SR605 Receiver
Audio vs Video
Happens mostly on your local channels right? This is a issue with the local broadcaster and not directv. Due to the digital transition this has been a widespread issue. Until the local affiliate for NBC, ABC, etc. fully transmit a digital signal then this sync problem is to be expected.
Mar 17, 2007 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
269 people viewed this question
Top Televison & Video Experts
