Problem withi scientific calculator
How do i restore the basic math functions on my casio fx 115s calculator. When I enter a four digit number like 1155 and hit the plus sign it converts to 1.1555 times ten to the 3rd power
How do I get rid of the word "Fix" from the calculator display.
Posted on Jul 25, 2008
Your calculator is in scientific mode. When you start it up it probably displays DEG SCI.
You got to this mode by pressing the MODE key 3 times and choosing option 2. You can change this by pressing the MODE key 3 times again. which gives you the three choices:
1: FIX 2: SCI (The mode you're in) and 3: NORM (for normal mode)
Choose 3 and you are all set!
Posted on Dec 13, 2008
  • polinco Dec 13, 2008
    The Fix problem is the same as the SCI problem: press MODE three times and select option 3.
I've got a casio fx 991plus calculator and I want to know how to use feet and inches in the calculation displays, like how is used meters and centimetres in the display
PDF]fx-570MS/991MS Additional Functions - Support - Casio
support.casio.com/pdf/004/fx570MS_991MS_E.pdf
Casiodisplay format (Disp) settings while the calculator is in the BASE ... Be sure to checkthe current calculation mode (SD, REG,. COMP ... Use [ and ] to display the expression 4 + 4. Press A ... want to perform scientific function calculations. COMP .
The Casio fx-991es, fx-570es and - Numericana
www.numericana.com/answer/casio.htm
The Casio fx-991ex succeeds the fx-991es (functionally identical to the ... Both are nonprogrammable nongraphing scientific calculators, with natural ... Side-by-side comparison of the fx-991EX and fx-991ES PLUS. ... Displays QR codes for smartphone use .... Work out a formula for many values of the input variables.
CASIO fx-991MS Calculator Tutorial: Lesson 5- Dealing with ...
Dec 03, 2015 | Casio Office Equipment & Supplies
Save equation fx 991es
In table Mode you can enter the formula for a function and generate a table of values. For a 991ES Plus you can enter two functions. However if you change MODE everything will be erased.
In EQN (equation) there is a certain number of built in formula types you can choose. You will be asked for the coefficients which will be used to solve the equation selected. However if you change MODE your lose what you entered. So basically you cannot save formulas to use as a memory aid (if that is what your intention is.) Sorry.
Jul 19, 2013 | Casio FX991ES Scientific Calculator
How do I use binary
Press MODE then 4 to select BASE-N mode. Press SHIFT log to select binary mode. Use the digits 0 and 1 to enter numbers.
You can do basic arithmetic as normal. You can access additional functions by pressing SHIFT 3 to select the BASE menu.
Aug 25, 2010 | Casio FX-115ES Scientific Calculator
How to change or put math mode without fractions or scientific notation on calculator fx-155 es natural display
I am not sure what you want because the mathIO mode IS THE ONE THAT DISPLAYS results as fractions.
You have two display modes: MthIO (with fractions, radicals) and LineIO (with decimals). Which one do you want?
To set MthIO press [Shift][MODE][1:MthIO]
To set LineIO, press [SHIFT][MODE][2:LineIO]
Concerning the scientific display mode.
Decimal numbers can be displayed in various formats, Fixed,Scientific, and Normal. If you do not want scientific display of results, just set the mode to Fix(ed) and specify the number of decimal digits. However if a number to be displayed (a result) is too small or too large IT WILL BE DISPLAYED in scientific format regardless of the mode you selected.
May 13, 2010 | Casio FX-115ES Scientific Calculator
Press SHIFT MATH 2 to switch to the LineIO mode. You won't see fractions then. However, if magnitude of the number is too large or too small, the calculator will switch to scientific notation in order to fit into the display.
Mar 22, 2010 | Casio FX-115ES Scientific Calculator
How do I get a casio fx-115ES out of scientific notation
Press [SHIFT][MODE][6:FIX]. You are then prompted to enter a number between 0 and 9. The number you enter fixes the number of decimal digits your results will have. If you press 0 all numbers will be rounded. Setting two or three decimal digits should be reasonable for most situations.
Jan 04, 2010 | Casio FX-115ES Scientific Calculator
I am trying to get the calculator in "basic math" mode. displaying the answers in "basic form" unless i am selecting otherwise.
The calculator has two Input/Output modes: MthIO and LineIO. Since I do not know exactly what you mean by "basic math" mode or "basic form" I must summarize some properties of each mode so that you can recognize your "basic math" mode.
  1. In MthIO, you have access to the multistory templates to enter fractions with a horizontal fraction bar etc. the exponents for the powers are raised above the main line, etc.
  2. In LineIO, what you enter in calculator is all on the same line, fraction and radical results are displayed as decimal numbers, etc.
The calculator is by default in the MathIO mode. If it not, you can restore it by pressing the key sequence: [SHIFT][MODE] (SETUP) and select [1:MthIO].
To set the LineIO as the default, you press the key sequence: [SHIFT][MODE] (SETUP) and select [2:LineIO].
Hope it helps.
Thank you for rating the solution.
Dec 14, 2009 | Casio FX-115ES Scientific Calculator
Does the fx-260 SOLAR do exponential calculations?
Yes it does. All scientific calculators do logs, power, roots, exponential, trigonometric functions. Most do also hyperbolic and inverse hyperbolic functions.
Hope it helps.
Aug 16, 2009 | Casio FX-260 Calculator
EXP or ee button i cannot find
x10 to the power of x is the EXP button, just press this and then the number it is to the power of!
Nov 20, 2008 | Casio fx-300ES Calculator
How do I calculate exponential functions?
The y^x button is right next to the x^2 button. It is labled with an x raised to a square box (which I will write as x^box). Thus, if you enter (for example)
2 x^box 5 = 32
Mar 30, 2008 | Casio FX-115ES Scientific Calculator
561 people viewed this question
jasbo
jasbo
