Question about Frigidaire PLEB30S9DC Electric Single Oven
Wattage for oven pleb30s9fc
Could you plese tell me what the wattage for this oven is so i could get proper wire size
  • Connected Load (kW Rating) 240/208 Volts: 3.5/2.6
  • Amps @ 240/208 (Approx.): 14.6/12.6
  • Minimum Circuit Required - Amps: 30
  • Bake Element Wattage 240/208 Volts: 3400/2554
  • Broil Element Wattage 240/208 Volts: 2750/2065
  • Armored Electrical Cable
What kind of wires did you buy?
Posted on Jan 05, 2009
What is the power requirement for installing a Simpson 2001 66-647 thermaflow freestanding oven?
For Electric Range - 220 - 240 volt, 60 hertz, properly grounded circuit with 40 amp breaker or fuse protection with #8 gauge wire. With a 50 amp breaker, # 6 gauge wire is required.
The owner's manual below mentions the wattage. (download the document, hit CTRL-F on your keyboard, type in wattage.) You might contact the manufacturer or for that matter the electric company servicing you.
https://john.daltons.info/appliances/Simpson_2001_models_68-642_and_68-646.pdf
Jun 11, 2017 | Ovens
Converting a panini grill into a crepe hob. Removed top element, now bottom element draws to much on lowest setting. What can I put inline or parallel to negate the loss of the second element?
Big wattage resister or variable one till ya find what works as for size got to know wattage of removed element Maybe the answer
Jan 30, 2017 | Ovens
Need part for an older Gibson wall oven
IF YOU CAN NOT FIND ONE ONLINE HAVE SOMEONE INSTALL A GENERIC THERMOSTAT BUT BE SURE THEY ARE KNOWLEDGABLE TO DETERMINE PROPER VOLTS / WATTAGES
Apr 21, 2014 | Ovens
I put in a Frigidaire Wall Oven and when I hooked up the three wires, Red, Black, and White all power went out on fr ont control board. What happened? is there a reset button? Model number PLEB30S9FC
Sounds like something is not correctly installed or connected. You could have a wire crossed, loose, or damaged. I would strongly suggest to have a professional handle this for you because you might have a faulty control board now.
Jul 21, 2012 | Frigidaire Ovens
Thinking about buying a new GE range that has a 3000 watt specification ... our home is sixty years old and wondering if the wiring (240 v) can support the wattage. I don't know the wattage of our old...
Calculating necessary breaker size using ohms laws, says 3000 watts at 240 volts would use 12.5 amps and most range circuit breakers are 30 amp so it should be find
Aug 01, 2011 | GE Ovens
Correct wattage bulb in Simpson La Scala electric oven.
if you are refering to the light inside the oven, I dont think there is a problem with wattage as the oven is rates to high wattage
and it is also inside the oven, so in an area that can cope with heat.
if possible check remove the old bulb and check the wattage on the glass or on the side of the fitting.
I personally would recommend that a 40W should be suitable.
I hope this was useful
May 23, 2011 | Ovens
What bulb is it in the oven
The bulbs are small wattage ones aroung 10-15 watts.It will be better to look for the same configiration of size and shape.
So remove and take the buld as a sample to show this to the persons around you for advice.. same pin type should be seen
Sep 11, 2010 | Whirlpool RBS245PDS Electric Single Oven
Hi , i am an electrician installing a westinghouse pek1380w-r stove , my mate that bought the stove is still waiting for the manual and cannot tell me how many amps the stove will draw so i can select a...
this unit will draw up to 50 amps if all burners are operating. i do not know the exact wattage, but they usually have an 8 gauge wiring connector already on the oven, if a wall oven.
if a free standing then you will have to put on a cord that will also be an 8 gauge.
you will need to determine what wire gauge to use depending on how long of a run you have from the circuit panel to carry the load.
it is also a single phase 240 volt system, but that doesnt matter because the wires are the same.
are you new at being an electrician? check your code book to make sure you are doing this wiring by the codes for your area.
Jan 12, 2010 | Ovens
Need to change oven from 440 3 phase to 220 single phase hobart cn90 oven
It can be done with a transformer, 480/ 240 single phase transformer to get the lower voltage. Then the oven will require some wiring changes to get all the elements and controls connected to two hot wires instead of three. The transformed will be sized to the wattage rating of the oven. This is a only basic description of what needs to take place.
Sep 05, 2009 | Hobart Ovens
What is the wattage of this unit?
Look on the spec plate for volts and amps. Multiply volts times amps for watts.
May 23, 2009 | Ovens
Frigidaire PLEB30S9DC Electric Single Oven Logo
197 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
