Question about ASUS P5S800-VM Motherboard
Not booting Up when power on
When I start my pc by power switch on, green power light is on and my DVD drive green light blinks but system not booting up. But when use restart button on the CPU box 2 or 3 times, PC starts working fine.
Changed Power supply box still the same problem.
Please suggest a solution for this...........
  • 781 Answers
Try setting your BIOS to default as it seems like someone or something has changed settings
Posted on Jul 25, 2008
I force removd keyboard witht shutting down the PC n the laptop shutdown. Since then screen only shows a milli-seconds deem light. DVD rom light blinking. Fan not turning, only a blinkin green light.
This is a very common problem with windows laptops. This may or may not help but here goes. unplug power. then unplug battery from laptop. Now plug only power cord into laptop. Now turn on and start tapping the F2 fuction key. Once it goes into bios make sure that your boot order is cdrom first. Then save it and reboot with the bootable cd in the drive.
Also if now of this works unplugged Hard drive and see if it will boot up at all and into the bios setting. If you are not able to boot into the cmos make sure also that no cd is in the cdrom drive.
Take your time. Good Luck.
Aug 26, 2015 | Computers & Internet
Why is the disk drive green light off an on no power up of computer?
If you're talking about the light blinking on the CD/DVD drive when you try to turn on your system .. that's because it's getting enough power for the disc drive to run it's onboard boot circuits. Does not mean that the rest of the system is getting the power it needs .. could very well be that your main Power Supply Unit (psu) is going out.
Note :: PSU's are one of the most frequently replaced items in desktop systems. Many new systems come under-powered and upgrades that place more demand on the power supply will stress minimal psu units.
When I replace them, if at all possible, I put in stronger ones so they do not stress and wear out as quickly.
If you're talking about the actual Power LED on the computer blinking, its most likely an error. The 8200 has a set of LEDs on the back to indicate various failure codes. You didn't mention beeping so its not a beep code, which exists as well. If any light other than the CD/DVD disc light is what you were talking about, please clarify or visit [Link shown below] :: the Dimension 8200 pdf manual link, codes in it.
May 10, 2014 | Dell Dimension 8200 PC Desktop
Wi-max light deep blue Power and charging and battery light blue-white HDD light blinking
Make sure your dvd rom does not contain a disk.
Your system checks your dvd rom drive first for a bootable disk.
A blinking HDD light is normal during boot up.
Feb 06, 2013 | Toshiba Satellite Computers & Internet
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
Jun 03, 2012 | Dell Dimension E521 (D10E16) PC Desktop
Dimension 8400 will not boot and more.......
I would recommend testing the power supply as Dell PS's are not known to be "forever". A power supply tester can be purchased online at for around $20 and they are fairly easy to use (you can also get a new PS there if necessary). If that is not it, I recommend going to a local small computer shop and picking up a used Hard Drive (be sure to get SATA), and switch it for your main HDD,, if the PC starts up and goes to an "Error no OS found" or the ilk, the culprit is your hard drive. I am in CT and fix PC's for a living, I am A+ certified and have passed all the dell Factory Cert tests. If you need help and are in the area or work well over the phone,, let me know I CAN solve this problem.
Aug 04, 2009 | Computers & Internet
System wont power on unless mb power connector on mb is reset
by mb pwr connector do you mean the swich on the pc case that you press to turn it on or do you mean the large block connector form the power supply ?
If you mean the case switch then you have a faulty one that is sendinga constant signal and locking up the power supply
Jul 17, 2009 | HP Media Center m7060n PC Desktop
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
On my HP Pavilion I set the BIOS to change the boot order from the CD drive first. Then I intalled Fedora 9 and when I tried to reboot the machine will not boot. I have tried booting with the Win XP cd in...
try resetting all the connections and also disconnect the power cable from the back of the computer and hold down the button for 10 seconds and start the system that should work
Feb 01, 2009 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
ASUS P5S800-VM Motherboard Logo
183 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
