Water Heaters Logo
Posted on Feb 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Floor of space is 16 sq meters. Second space is 4 meters wide and 5 meters long. Which space is bigger?.
Anonymous
Level 2:
Champion:
  • Expert 235 Answers
  • Posted on Feb 16, 2011
Anonymous
Expert
Level 2:
Champion:
Answers
235
Questions
Helped
75838
Points
387
Second space is 20 sq meters.
I have a Superflue electric fired gas powered water heater. For the last 3 months it will quit working there will be a little tiny puddle of water on the floor. Our plumber who installed the heater came &...
See page 15-16 of owners book
d55i3tvttakuaaaaaelftksuqmccaa==
You may need expansion tank, as water heats ether may not be enough space for water to expand as heated. perhaps a different plumber or company.
New tankless bosch unit, luke warm h20, gas line 1 inch direct to tankless, gas company came and gas psi ok. Plumber said we can not adjust the gas pressure above 5.5 inches of water at the meter. hel
1) Add tempering tank to preheat incoming cold water.
http://waterheatertimer.org/Tempering-tank.html
2) Read product manual or call Bosch to make sure unit works with pre-heated incoming water. Some incoming water sensors will not trigger combustion is incoming water exceeds certain limit.
2a) Read product manual for required yearly/monthy maintenance.
Train wife to delime tankless yearly.
3) Install bigger gas meter.
4) Solve entire moneypit problem today for $325
http://waterheatertimer.org/How-to-install-gas-water-heater.html
5) Don't install tankless unless you have a lot of money and time for headaches.
Don't believe promotional literature. Tankless promotion is BS for average do-it-yourself folks who want to save a buck on water heating. Estimated yearly saving of $100 means Tankless do not save money long term. All costs are energy: Purchase price and installation negates several years saving up front. One repair will negate another 5-8 years energy savings. By then you need new unit.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
What Atwood water heater models will replace model GCH6A-9E?
Any 6 gal will fit in same cut-out (hole) . 12-5/8" H x 16-1/4" W x 17-5/8 deep. In order to move up to a 10 gal, you need to be able to cut hole a little bigger. 15-3/4" H x 16-1/4" W x 20-5/8" deep. Usually your depth will allow , and width is same, just a matter of whether you have room to make height bigger.
Make a electric water heater elements come on at same time
1) You want simultaneous operation.
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html#simultaneous
2) Installation REQUIRES bigger circuit breaker and bigger wire.
Or 2 circuit breakers and 2 wires
Or change both elements to 2000 watt.
http://waterheatertimer.org/Color-codewire.html
3) MUST add ECO-protected thermostat to lower part of tank.
4) Warranty will be void.
5) If tank is rusted, the added heat and expansion could hasten rupture.
http://waterheatertimer.org/Replace-anode-rod.html
6) As general rule, the health department will not allow this tank conversion for restaurant code to meet dish washing consumption unless manufacturer certifies tank.
But manufacturer will not certify ordinary residential water heater for commercial simultaneous application. Commercial simultaneous tanks can cost 2-4 thousand so they can meet restaurant code and deliver sustained high temperatures for washing dishes.
6) Also consider Hatco booster heater for commercial dish washing.
This type heater has 2 sets of non-simultaneous elements to heat large tank of hot water.
I have a Whirlpool 40 gal. electric water heater with a box on top that lights up and blinks to let you know of any problems. The other day it blinked that the upper element was defective, I installed a...
It sounds like the box is bad.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
For second opinion:
Call Whirlpool number that shows in manual.
Person answering phone will want product number and serial number that is located on label on side of tank
Manual says:
1-877-817-6750
When calling for assistance, please have the following
information ready:
1. Model Number
2. 7 Digit Product Number
3. Serial Number
4. Date of Installation
5. Place of Purchase
A very old rheem fury water heater i assume it's just worn out but because of a space problem i can't go wider than the 15 inch diameter it has.
16" diameter water heaters could work if you cut away the metal and insulation off of 1 side of the water heater. The actual tank inside the shell is smaller than outside diameter.
American gas water heaters shows a 30gal 16"
model BFG61-30T30-3NOV
http://www.americanwaterheater.com/products/pdf/NRGSS00107.pdf
AO Smith has 16" Promax 30 gallon gas
Model GCV30
http://www.hotwater.com/lit/spec/res_gas/ARGSS01406.pdf
ELECTRIC 6 gallon point of use
http://www.hotwater.com/lit/spec/res_elec/AOSRE50400.pdf
You can get a tankless water heater if you have the additional money and a water filtration and softener system and don't mind expensive repairs if you install it yourself.
Water heather does not com on when water is truned on wide open
when to local dist. got owners manuel which after installing 4 of these uints the person impersonating a plumber took with him. easy to understand tbl shooting. resolved tbl. thanks
I can not find the furnace in our home. Is it in the attic??? or crawl space??? i have a newer home in Phoenix
it could be an air handler in the attic, do you have gas or ele. some are built into the water heater if it is gas, do you have base boards running around the bottom of your floor or air vents with am ac condesor outside if this is the case it could be either the crawl space or attic
2answers
New water heater, shower hot then only warm water in 5 minutes
try this, set the bottom therostat if it is electric , 10 degrees hoter than the top is set , if gas have no ideas
Top Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Water Heater Expert? Answer questions, earn points and help others
