Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
I need a user manual
On the bottom of my charger it says HC014700. No other number on the hand helded units. They are yellow and black and were bought at Costco. I need a user manual.
  • Anonymous Aug 28, 2008
    I need a User manual for a T 5210 Motorola WKY-TKY
    Thanks
  • 123 Answers
VEC012POB Manual
Vector sold to Black & Decker who then sold to Bacchus. The only manual I find with the same number you show is NOT yellow and has no USB connection. It is charged by a 110 volt wall wart charger that plugs into a receptacle on the unit, or a 12 volt cigar lighter cable that plugs into the 12 volt port on the unit. Here's a brochure for the model number you provoided:
May 31, 2014 | JUMP START SYSTEM
Braun 4169 user manual
i could not find a user manual but follow this link to a schematic of the machine and its parts numbers hope this helps you
http://www.1800parts.com/images/1800Parts/English/products/standard/4169-Schematic.pdf
Sep 17, 2012 | Braun Hand Held 120 W Mixer Model 4169 In...
Still needing manual
stick with fixya or google it.
Apr 16, 2012 | Welding Tools
We have a Dirt Devil Scorpion hand held 6.0 volt DC vacuum model BD10050 manufacturing code B10C. Is it best to leave it plugged in or not? It does not say AccuCharge anywhere on the body or on the...
If it is a NiCad or a NMh you should only charge it when it needs it. A lithium can remain on the charger. Your battery packor the bottom of the machine will have the marking of what kind of battery it is.
Jun 06, 2017 | Royal Dirt Devil BD10050 Scorpion...
I bought a Ryobl Power Drill 14.4volt last week at a D.I.Y. store and have found when charging the batteries the light on the charger is Yellow. In the instruction manual they only mention Red when...
yellow usually indicates a HOT battery and is waiting for a cool down before recharging or it can mean a defective battery/charger. If you just bought this unit I would take it back for warranty replacement.
Jul 09, 2011 | Ryobi Drills
I bought a B&D JUS500IB jump start system. Their is no paperwork or manual in the box. How do i get a manual for this unit.
You can try going to Dewaltservicenet.com and in the middle of the page towards the bottom is a box for manuals/schematics. Type in your model number and it will tell you whether they have it or not, if not there is a box for contact us and you can request one be sent to you.
Nov 16, 2010 | Black & Decker Hand Tools
We ran our Platinum Series 18 volt hand vac until it stopped -- charged the battery overnight but it did not charge. is there a problem with the battery charger or what could cause this?
Most problems with what you have stated have to do with bad contacts between the hand held unit and the battery charger. With the charger unplugged, make sure the contacts on both the charger and hand held unit are clean and not bent. Check to see what the "Light Indicator" should be when charging and reinsert the unit into the charger. If the light does not show what it is supposed to show, move the hand held unit around a bit to see if you can make the connection better.
If this does not do the job, depending on the age of the unit, might be time to replace the battery.
Oct 06, 2010 | Black & Decker CHV1500 Bagless Handheld...
My porter cable 19.2v model 8605 battery charger
Porter Cable has not offered a replacement for their poorly designed 19.2V chargers. I had the same problem and happen to like my drill and circular saw. I found a universal charger called a model number CHUN-2420. Google it--I got mine for $27 plus shipping. All you need to do to make this work is splice 3 wires.
My charger is a PC model 8624, so the instructions might vary slightly between the chargers. Remove the six screws on the bottom of your PC charger. Remove the bottom section. Remove the screw(s) that attach the circuit card to the plastic housing. Disconnect the 3 pin white charging connector from the circuit card, and cutoff the connector. Discard the circuit card and power cord. Cut the 3 conductor (red/yellow/black) cable coming out of the Chun-2420 approximately 2' from the charger. Splice these three wires to the three wires in the charger housing that connect to your battery. In my situation, Red/Red, Yellow/Yellow, White/Black. To verify, red=positive, black/white=negative, yellow=temperature sensor. Wrap the red/yellow/black cable with electrical tape where it exits the PC charger through the power cord hole. Re-attach the bottom.
Jul 24, 2010 | Porter Cable 19.2V Drill Kit
I just bought a new laptop yesterday and when i plug in the chager it dont chager it said plugged in not charging so idk what to do thankxs
On the front of the laptop or near the screen you should see a light that shows one color for when it is running on battery and another when it is charged. Usually yellow when charging and green when charged.
As well when you boot into windows near the clock you will see either a battery when using the battery, a plug with a lightening bolt when charging and just the plug when you are 100% charged.
In your user manual you should find a few picture that show and explain where and what all the light or indicator mean. If you go under control panel ot right click the icon near the clock then you get into the power panel.
If you are new to laptops it is a good idea to have the manual open and go over everything to familiarize yourself with what and where. Then you will avoid what I did when I first bought a laptop and couldn't get the wireless to work. If only someone had read manual and saw where the switch was ;-] Enjoy your laptop once you get used to things they are hard to be without.
Nov 04, 2009 | Dell Inspiron 1525 Laptop
Need instruction manual for meridian color magellan p/n 800482-01
Yahoo's user group called Magellan_Meridian has manuals and great information on all models.
Dec 04, 2008 | Magellan Meridian Gold GPS Receiver
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
