Question about Tascam US-144 Sound Card
Recording on cubase
When i go to record vocal tracks the mic volume is on the max and in the headphones i can hear myself loud and clear but the recording on playback is coming out very low and small and i am new at using the tascam us-144 , and condensed mics and phantom power what do i do to get good quality sound
Man did you solved your problem? because i have the same problem and i don't know how to solve it. if you solve it please tell me how to. Thanks (:
Posted on Nov 29, 2011
    Problem Solver:
  • 6 Answers
Remember when recording in 24-bits, you have 8 bits EXTRA over 16-bit recording, per voltage sample.  This means that for each voltage step that would be recorded in a 16-bit recording, a 24-bit recording will take 256 steps!  In other words, the fidelity is MUCH greater, so even if your levels seem low, that can be OK, since you have around 100 dB of headroom to play with, and can increase the signal many times with acceptable fidelity.  What you DON'T want to do in digital recording is CLIP, which is a virtually unrecoverable fault in the recording.
Posted on Sep 06, 2008
Hallo i have cubase sx3 I can get my backing music onto track one via importing it from docs - no problem - how do i increase the volume on record as the tracks from vocals dont come out loud at all ,...
You must adjust the record level from the input device - i.e. mixer or soundcard. There is no input level control within Cubase. It is often the case, however that the problem lies with the backing track being too loud.
May 28, 2011 | Steinberg Cubase SX3 (502010600) for PC,...
How do i get levels from my g track mic im using cubase le 5 i only get one side level how do i fix this issue?
The mic is only on the Left channel, and instrument input is on the Right channel. So in Cubase you need to select only the Left channel in your first track, and then only the Right channel in your second track, and then you can record Vocals and Instrument at the same time on 2 different tracks.
May 02, 2011 | Samson G-TRACK USB RECORDING MICROPHONE...
Using a Tascam US 122 with Cubase SX, when recording vocals red light (clipping) on the Tascam and in the Cubase mixer, I need to know how to set levels on Tascam, so there will be no clipping on vocal...
Make sure the switch is set to "mic/line" and not "guitar"
Your input level will be set by the "input L" or "input R" knob, depending on which side you are using. Start with them all the way down and then sing into the mic, turning them up until you get a signal about halfway up the bar in Cubase. That should give you plenty of headroom for clean vocals.
It may be difficult to get a good sound if you have one of those cheap mics that has a "1/4" jack instead of a 3-pin XLR jack. You might want to go to your local music/pro audio store and invest in a "condenser" microphone, which is good for vocals in the studio.
Feb 26, 2011 | Tascam US122 Audio/MIDI Interface with...
Good morning I have Cubase SX version 1.01. lately when I record vocals to a track. Im noticing that the Vocals are not in sync with the music. one is playing slower than the other track.. the slower is...
I don't 100% understand why Cubase does this. I'm assuming it's a memory (RAM) problem. If you record loud and clear anough you can just drag the tracks to where they're meant to be afterwards because you can see where they go relative to the other tracks
Aug 20, 2010 | Steinberg Cubase SX3
No sound in playback (but can hear click track)
This might seem simple, but just to check: you have switched off the monitor on the track when you go to playback? With track monitor engaged, you will not hear playback, but will continue to hear the live monitor.
Sep 26, 2008 | Tascam US-144 Sound Card
Cannot record
Im having the same probz, got a Hp Pavilion Vista using mobile pre amp usb when i record using a condenser mic XLR nothing is picked up from the channels in Cubase or Nuendo. Im trying to record vocals but the Mic is not picked up and i cannot hear myself in the headphones and it wont transfere to cubase.
It has worked before when i had a desktop, but this only worked with a separate m-audio sound card inside the desktop and i plug in the output jax leads from the desktop (soundcard) to the m-audio usb pre amp
Is this why it is not working for the laptop do i need a Jax connection and where is this audacity
Sep 15, 2008 | M-Audio M AUDIO MOBILE PRE - USB MIC...
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
bd.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
Vocal effects on Tascam 2488 MK 2 portable studio
Hi again,
The easiest way to record using an external Lexicon effects unit (without an external mixer) is to connect your mic onto one of the 2488's inputs and assign that input to a channel strip (track). You should have the 2488 sends (output) going to the Lexicon's inputs. Then connect the Lexicon outputs back into another set of inputs on your 2488 and assign those inputs to two empty channel strips (tracks).
Then you will have to take that channel that has your mic input assigned to it and press send and set the levels there to send the signal out the sends (to the Lexicon).
Now you have a channel strip assigned to the mic input which contains your dry signal, and you have the two inputs returning from the Lexicon which contains your wet or effected signal.
You then have some options. You can control the amount of effected signal you hear while recording by adjusting the faders of the two wet tracks and you can either record the dry signal or the wet signal (or both) onto separate tracks.
Typically when recording the singer will want to hear an effect (say reverb) on his voice, but the engineer wants to record only the dry track at recording time (because effects can always be added later, but they can't be taken out). To accomplish this you would use the setup above, but only arm the mic input track for recording. In this way the singer hears the reverb, but only the dry vocals get recorded and the engineer can add reverb to that track again later as desired (and mix it back with the dry vocal etc).
On the other hand if you want to record only the effected signal you would simply arm the two channels to which the inputs coming back from your Lexicon are assigned for recording. This will get you a recording of the effected signal only.
Hope this helps you do what you are trying to do.
Cheers.
bd.
Aug 30, 2008 | Tascam 2488 Portastudio Multitrack...
Recording with condensed mic and phantom
Some (very) basics with any live audio recording:
  • Have a very very quiet space in which to record, with good acoustics (this means a room that will give a flat sound, preferably one with carpeted walls and celings, but any small, well-furnitured room should do).
  • Do not mix with the interface. Simply put the gain as high as possible without clipping and mix later in your recording program (Cubase, in your case). You can always bring the level down, but trying to gain an already recorded track will introduce noise.
  • If you are recording vocals, use a pop filter. When recording anything, experiment with different mic positions to attain the best possible, clean sound.
Jul 25, 2008 | Tascam US-144 Sound Card
Tascam US-144 Sound Card Logo
162 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Chris Larocque
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
