Speakers and OHM's
I have two realistic mach one speakers and the woofers are compleatly messed up and need to be replaced. On the magnet of the woofers it says 6 Ohm's, i want to know if i can replace them with a 4 Ohm woofer. By using a 4 Ohm woofer would it fry the internal crossovers, or do any damage to the tweeter or mid. or anything elce?
  • sub guy Jul 25, 2008
    Are you sure, these speakers were very expensive.
Hi my name is kelly, i also have a set of mach ones but mine are not liquid cooled thay are the first model before the liquid cooled which is model number 40-4024a not 40-4029. in that case i have asolution to your problem i know of a place that can totaly repair the hole woofer,the surrounds,the dust cap the hole thing back to its origianal look and sound. go to www. speakerex.com and talk to a rep, this company has been reparing speakers for many years, thay are located in orlando florida i have already talked to a rep already and thay have givrn me prices already if the speakers need to be refoamed it would cost 50 to 75 dollars to fix, or if they are realy messed up bad they can be totaly reparid back to brand new for 90 dollares each plus shipping thanks kelly
Posted on Aug 28, 2009
It will work temp. but it may put to much of a load on the receiver
Posted on Jul 27, 2008
  • 40 Answers
It should be fine, just dont go under 4
Posted on Jul 25, 2008
How do i know if woofer is shot?
No sound come out or it is greatly distorted.
Sep 06, 2017 | Audio Players & Recorders
I hooked up my xd1225 cd player in my car and it gets SUPER hot/overheats. What did I do wrong?
your speakers are of an incorrect ohmage, or you have too many speakers hooked up to it. your stereo likely calls fo a singler 4 ohm (4?) speaker per channel and the factory speakers may be lower than 4 ohms, or you have several speakers hooked up to the same channel. there should be 4 channels, each with no less than a 4 ohm (4? ) load. two 4 ohm speakers wired to the same channel in parallel (both attached to the amp's poositive/negative leads) will create a 2 ohm (2?) load, and overheat the amp. if the 2 speakers are a woofer/tweeter combination, and there is a capacitor involved, it may be ok, but 2 woofers, or a woofer and a subwoofer hooked to the same channel will likely reduce the ohmage below 4 ohms (4?). look at the back of each woofer speaker, and look for an ohmage rating stamped to the back of the speaker magnet to verify that they are 4 ohm (4?) speakers, and verify that only a single 4 ohm speaker is hooked to each channel. the car likely has multiple speakers hooled up to each channel, which would lower the ohmage rating below 4 ohms (4?).
Mar 09, 2011 | Dual Electronics XD1222 Car USB Player
The mid/bass is blown on my Sapphire SB bookshelfs and I cannot find replacement drivers. They are 5 inch 4 ohm but no manufacturer data. Any suggestions
http://www.parts-express.com/resources/woofer-selection-guide.cfm
Sort the guide by woofer size. Measure and match the hole opening, approximate volume of the speaker box and the -3db cutoff specified by Sapphire to something in the guide. Look for 4-ohm models, of course. Also, if you know the sensitivity rating (87db or similar), shoot for the same rating.
In order of importance -
DB match - get it wrong and the speaker will sound dark or bright.
Impedance match - get it wrong and the crossover frequency will not be correct.
Volume / F3 match - Will affect bass response.
As Sapphire is long gone, aftermarket replacements are your best bet. You might be suprised at how good a shot in the dark will sound. PE has a good return policy if you take care not to mess up the drivers during tryouts.
Jan 14, 2011 | Sapphire Technology SB Main / Stereo...
What is the wattage capacity of Sound Tech CX4C PA Speaker? yeah! brand: Sound Tech/ model CX4C. thanks..
SOUNDTECH CX4C 2-way monitor wedges (2).
380 Watts Power / 190 Watts RMS, Full Range 2-way, 12" speaker, 1" Compression Driver(horn). Carpet Covered, Pole Mount capable, 8 ohm.
Impedance - 8 ohm
Woofer Size - 12"
Magnet Weight - .
Voice Coil Dia. -
H.F. Driver/Exit - 1"/Compression
RMS Power Rating - 190W RMS(8 Ohms)
Dimensions - 18.5"w x 16"d x 27"h
Weight - 52(lbs.)
Aug 31, 2010 | Sound Design Lifeworks Technology iHome...
Can a kicker cvr be fixed if it is blown if so how
Speaker lesson here. For space and time, I'll not get into certain nomenclature. Working from top to bottom, you have the cone, rubber surround, basket, spider, voic coil former, voice coil, and the magnet. The binding posts are connected to the tensil leads which connect to the spider and the voice coil. As the woofer is positively + and negatively - charged, it creates a magnetic field which moves the woofer up and down. There is a small gap between the magnet and the voice coil and former that's called a magnetic gap. This gap is what helps the speaker to move up and down, and creates the Xmax. The Xmax of the woofer is the maximum linear excursion the woofer can travel without causing permanent damage. With a blown speaker, normally the voice coil and voice coil former have been pushed out of the correct magnetic gap, usually around the top of the magnet. That means that the only way to fix it is to take the woofer completely apart. My suggestion is to just go and spend the money. A blown speaker is a sign of abuse, and voids warranties from the majority of companies out there to include Kicker.
May 04, 2010 | Jl Audio CVR12 Kicker 12" CompVR Series...
I have dropped one of my mackie srm450 speakers and i need a replacement woofer.. where can i get one?
If the cone is damaged, it is possible to get it 're-coned'. If you can find a shop that does this type of speaker repair.
Otherwise, call around music stores (by that I mean places that sell musical instruments and PA gear) and see if they sell/sevice Mackie. If you are comfortable taking the old woofer out, just order the part and DIY.
It is not critical that the woofer is an exact replacement (doesn't have to be a Mackie speaker), the important things are:
1) it fits and screws back into the speaker cabinet
2) it is electrically similar to the original (same impedance 4 ohm or 8 ohm) and wattage rating
Feb 06, 2010 | Mackie SRM-450 System
WHAT KIND OF AMP SHOULD I USE ON SOME ICBM-5612
You can use any type of amp as long it can drive at least 1000 watts and it 2 ohm, 4 ohm or 8 ohm stable.Here is the specs on the woofer:
  • 12" High Performance Subwoofer
  • Rubber Seal Gasket
  • High Temperature 2" 4 Layer Voice Coil
  • Air Vented Aluminum Fomer
  • Dual Voice Coil ( 4 ohm + 4 ohm)
  • Large Foam Edge Surround
  • Bumped Plated For Maximum Excursion
  • Excellent For Sealed and Bandpass Enclosures
  • 70 Oz Magnet Structure
  • 1000 Watts Max
  • Frequency Response: 25Hz-800 Hz
  • 2 Ohm / 4 Ohm/ 8 Ohm Operation
  • Screw Block Terminal
Also check this website for how to wire it to 2, 4 or 8 ohms: http://www.bcae1.com/spkrmlti.htm
Dec 26, 2009 | Performance Teknique ICBM-5612 Car...
Replacing sub speaker
I wouldn't try reinventing it by replacing the driver. Drivers and their enclosures are designed to work together. And this being a self-amplified subwoofer, there is one more piece that's electrically optimized to the rest. Don't mess with it.
Why don't you just set your receiver's individual relative speaker volume levels so the sub isn't weak by comparison to your other speakers? Weakness, as you call it, is relative.
Is your receiver properly channeling Low Frequencies to the sub? Experiment with the cutoff, too.
This problem doesn't require meatball surgery.
May 18, 2009 | Sony SA-WM500 Subwoofer
Jamo Cornet 90IV
not sure what size you need but dayton audio subs are pretty killer check them our parts express usa, i a have a set of realistic mach ones with one of my drivers blown i did some searching and found parts express, due to rave reviews and the specs on what i look for in subs dayton is the way to go,happy hunting-z
Jan 10, 2009 | Jamo A4SUB Car Speaker
197 people viewed this question
 Grubhead
Grubhead
