Question about Dryers
Ceiling Fan only spins 1 speed
My daughter's ceiling fan used to work fine. I tried to put it on today & it is only spinning 1 speed, instead of the 3 it used to have. Any ideas on what may be wrong, or how to fix.
  • Anonymous Aug 25, 2008
    i have same problem
  • Anonymous Oct 28, 2008
    I have had this same problem and have it now again.
    I replaced the little box inside which appeared to be partly melted.
    I haven't looked this time yet to see what the problem is, but am guessing it is the same thing. I called Hampton Bay the last time and they sent me a new one after going over the problem with tech support. The only problem is you have to have purchased the fan within the last 12 months
  • 70 Answers
Assuming you havent messed about with the wireing it can only be the pull cord switch fault or the motor is on its way out
Posted on Jul 25, 2008
This concerns The post by rblg2d1 about the fan running on high only with the remote.I called customer service and they are sending a new remote.I don't know if this will solve the problem until I receive the remote.Meanwhile if anyone has a solution or any Ideas I would like to know what they are.Thank You.
Posted on Nov 05, 2008
I bought my Aloha ceiling fan 7 days ago.I installed it 2 days ago.It was working fine for 2 days.last night it was running and I had it on low.All of a sudden it started running on high.I shut it off and turned it back on and now it won't run on medium or low,just high.When I pulled the chain on the fan it works fine and has all 3 speeds,but not with the remote.Just high.When I push on the remote for the low setting it goes right to high.11/05/08
Where can I purchase a Jin you e70469 ceiling fan switch.
ebay 14 bucks
Jin You E70469 Pull Chain Switch for 3 Speed Ceiling Fan 4 Wire 1 2 ...
https://www.ebay.com > ... > Lighting Parts & Accessories
item 2 ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire -ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire. ... item 3 OEM ZING EAR ZE-208S 3 SPEED CEILING FAN PULL CHAIN CONTROL SWITCH E-89885 DR73 -OEM ZING EAR ZE-208S 3 ...
Exhaust Ceiling Fan Switch 2 Speed Pull Chain Blower Jin You ...
https://www.ebay.com/itm/...Ceiling-Fan-Switch...Jin-You-E70469...-/132376583704 Replaces Jin You E70469, Santa, Gardner Bender GSW-33. The control module provides two speed setting for your fan. 2 Speed Pull Chain Switch. 3" (7mm) Brass Chain. Spark Electric Components LLC. Width 11/16" (18mm). ' eBay!
Jin you e70469 ceiling fan switch Google Search
Dec 12, 2017 | Dryers
Why my selling fan does not spin faster?
It is a speed switch issue you will need an electrician to come in and repair or replace the switch for your ceiling fan as I had the exact same issue last summer with my ceiling fans. I hope this helps.
Sep 03, 2012 | Computers & Internet
Our ceiling fan lights are blinking. There are 3 bulbs that have always worked fine until yesterday when they all 3 started blinking in unison.
sounds like you have a lose wire, pull the light housing and check the connections. If all is good, drop the unit, and check the connections in the ceiling. You have a short in the power , and is showing you when the fan is spinning. I would not use light or fan till fixed.
Mar 13, 2011 | Hunter (25417) Ceiling Fan
Ceiling fan will not spin fast
in england the usual house current is 220 volts and here the current is 120volts. this explains the problem. unless there is a switch to change your fan to a 110 current built in it might make sense to buy a new fan and move on. rewiring it would be expensive and unless it has alot of sentimental value probably not worth it.
May 31, 2010 | Hampton Bay Dryers
Ceiling fan capacitor hook up problem. I have a 3 speed fan. 4 switch. A 3 wire capacitor - CBB61. Kids lost wiring diagram. Any which way I try to wire it up only one of the speeds works. Any wiring...
The reverse switch on my Hampton Bay ceiling fan didn't work. I cut the 6 wires; 1 white, 1 gray, 2 pink, 2 yellow. Here's what I did. Removed reverse switch. Had 6 wires white, gray, 2 yellow, 2 pink. Connected gray to yellow, connected white to pink and fan runs fine. Is this OK? I do not need to reverse fan. It's been running for 1 hour now with no problems. Don S.
May 15, 2010 | Dryers
Unable to reverse Thomasville ceiling fan rotation w/remote
I e-mailed Thomasville Lighting after my original post but did not get a reply. I then searched and found a similar problem on this site (http://www.fixya.com/support/t187540-ceiling_fan_not_reverse_remote) and read the Best Solution which mentioned running the fan at medium speed (not low), then pressing the Reverse Direction button....it worked. As stated in the original suggestion, this was very counterintuitive and not documented in the manual.
Apr 28, 2009 | Emerson CF2600PW Raphael Pewter Ceiling...
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Dryers Logo
4,393 people viewed this question
Top Dryers Experts
