Question about Maytag PYE2300AY Electric Dryer
How do we get to the termal fuse on a maytag dryer
The dryer wont start you plug it in and hit the start button and it does nothing a friend said it could be the termal fuse
  • 943 Answers
Hi yES IT COULD BE THE THERMAL FUSE . tWO SCREWS AT BOTTOM OF DRYER REMOVE FRONT PANEL tHETHERMAL FUSE IS LOCATED ON THE AIR VENT TO THE LEFT OF THE ELEMENT . THANKSFOR THE QUESTION THE APPLIANCE DOC
Posted on Sep 12, 2008
Where are the termal fuses on a maytag de309
On the front of the blower assembly
Jun 20, 2017 | Maytag Dryers
Maytag dryer stops running after 10-15 seconds.
Check the exhaust vent in the dryer and the one going outside, sounds like it's plugged. If it's plugged the dryer will get hot real quick and shut off so it doesn't catch fire...
Dec 11, 2014 | Maytag Dryers
Maytag dryer waont start when you push start button
Try opening and closing the door a few times it might be the door interlock switch, Are your plugs fused like in the UK. If so check fuse, or there will be a safety fuse inside the dryer which has blown in which case it will have to be examined by a qualified repairer.
Nov 13, 2011 | Maytag Performa PAV3200
Dryer makes click when push start button but wont start
The problem is likely a blown thermal fuse. This thermal fuse is wired in series with the motor and if it blows, power to the motor is terminated and the motor cannot run. No dryer function works when the motor cannot run.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Let us know if the problem is not addressed above but indicate the exact model number of the machine for further advice.
Feb 01, 2011 | Kenmore Dryers
Maytag dryer wont turn on i hit the push button and nothing happens i have light on in drum when i open the door any ideas of what it can be
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 11, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer wont start
Could be countless things. You neet to start testing every fuse, and switch with a volt/ohm meter
Jan 02, 2010 | Maytag Dryers
Dryer wont start
Hello. i can help you. begin by checking the power.
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
If that doesnt get it working again get back as there are other things that could have gone wrong.
Jun 04, 2009 | Dryers
Control board non operating
replaced the termal fuse(white). door switch ok?
May 22, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Alg643raw gas dryer
try unplug and plug back in first let it reset and if that dont work, check thermal fuse may be blown..the fuse located in the back next to the fan in the housing. If fuse blown unit not work, if you go to www.appliancepartspros.com choose your model and it will give diagram of location termal fuse. check fuse first make sure is blown before you order it.
Mar 31, 2008 | Amana ALG643RB Gas Dryer
Maytag Electric Dryer MDE308DAYW doesn't turn on at all when pressing the button
Since the vent was filled with lint I would check the High Limit termal fuse located on the front of the heater asm. It is best to replace the fuse and thermostat. These parts are part of a kit that can be purchased from your local supplier. The heater asm is located in trhe bottom left of the dryer. and looks like this
Jan 16, 2008 | Dryers
Maytag PYE2300AY Electric Dryer Logo
121 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
