Question about GE Microwave Ovens
JE1860SB 001 model
Small flames and then flashes of light within seconds of trying to heat something. Had appliance rescue person out and he said it was the magnetron. We ordered and replaced the magnetron and the same thing is happening. What's up? I'd appreciate any help you can give me.
Thanks in advance,
Carol
  • crice27 Jul 25, 2008
    I am aware of the fact that metal objects do not belong in the microwave. I had a "glass" of coffee inside which is how I have been reheating coffee. Any other ideas?
    Thank you,
    Carol
    Cleaning fixed the problem!!! I didn't realize the inside of the plate was dirty. Thank you very much!!!! I did have a repairman out and he diagnosed the problem as the magnetron and said it would be $427.00 to repair it. That's when I ordered the part online and replaced it myself for $110.00. As it turned out, I didn't even need that part!
    Thank you, thank you!
    Carol
  • GE Master
  • 13,433 Answers
  • Ekse Jul 25, 2008
    It looks like there's lightning (arcing) inside my microwave
    When you see arcing inside your microwave, it's because of food or liquid left in the cavity or on the wave-guide cover:
    • If the wave guide has any burn spots, replace it and clean the unit well.
    • If the cavity has any burn spots, spot-sand it smooth and touch it up with microwave interior paint.
    Note… If there are any burn holes in the cavity, don't use the unit-seek help from a qualified appliance repair technician.
  • GE Master
  • 19,396 Answers
The magnetron can flash if there is metal inside the microwave
Posted on Jul 25, 2008
  • 1 more comment
  • Ginko
    Ginko Jul 25, 2008
    Probably there is dirt or metal particles inside the ovenis. There should be a little square cover that rotects the magnetron from fats and food from getting on it, is called "the wave guide shield" this can also be dirty inside or damaged, make sure you clean up any fats where the shield fits, and if problems persist replace the cover that costs around $10.
  • Ginko
    Ginko Jul 25, 2008
    Always better having the job done by a repairman, if you recently had magnetron replaced by a repairman, and it did not fix it ask to have the cover replaced at part only cost.If it is under guaranty even better.
  • Ginko
    Ginko Jul 26, 2008
    I am glad you fixed, this is a common problem on microwave ovens.
Stopped working
* Please e-mail me directly with your FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
* William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Feb 20, 2017 | Microwave Ovens
Ge micro wave/ model# jvm1440bh01 manu 01 2005. All lights and turntable works,does not get hot. After it runs for a few seconds it changes to a lower and louder pitch. Tried to change power level and...
If the cabinet is intact and the door closes properly there is
absolutely no personal danger. Aside from the brain (timer,
temperature controls, etc.) there are four major components in the
cooking mechanism. They are:
1) step-up transformer
2) diode
3) storage capacitor
4) magnetron
The step up transformer supplies about 3000 volts ac which is
rectified to dc by the diode and stored in the capacitor. The
magnetron converts the high voltage dc to radio frequency energy in
the 3000 Mhz range which induces many small currents in the moist, and
conductive, food which causes internal heating by resistance.
Failure modes usually involve #2 or #4.
If the diode fails there is no heat at all and somtimes a loud hum or
buzz.
If the magnetron fails, the heat is reduced, or absent, and again can
produce a loud hum.
Snapping results from the microwave energy exciting some conductive
particles that can be due to residues in the cooking cavity, or
breakdowns within the magnetron itself. If the cooking cavity is clean
and there are no loose metal objects within it, you problem is most
likely to be a failed magnetron.
These can be purchased new for about $50 but there are tons of usable
parts from discarded appliances. A local technician should be able to
replace this part with a used one for less than $50 total. They come
in about 3 or 4 variations (physical mounting screws, etc.) but can
often be altered to fit safely and effectively.
IF the its within warranty get it replaced, I personally recommend a tech to work on it.......
Good luck..................
May 23, 2008 | GE Microwave Ovens
Flame Sensor not available
We could look it up if we knew your full model number, but some of their budget models (like some made for Wal-Mart) are made with only turntable parts available.
Within the warranty period, the oven is to be returned to the dealer.
But a fire would not normally be covered under warranty unless the oven came on by itself when idle.
Otherwise, the thermostat / TCO has temperature markings on it, and a generic equivalent or very close type can be matched at a local appliance parts store.
May 17, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Rival Microwave Model RGM41101 will not heat
If the lead and the plug are ok and the panel lights up, do not attempt any further repairs of inspection. A microwave is an extremely dangerous appliance and should only be serviced by qualified persons.
Jan 17, 2011 | Rival Microwave Ovens
Not heating up anything
Tat would be a magnetron problem. The magnetron is what provides the heat
Apr 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Model JE1860SB: microwave does not turn on. Was
The magnetron may have overheated due to a failure of the internal cooling fan, blocked air vent in the back, or a clogged filter, if so equipped.
You can find links to helpful exploded view diagrams and part ordering help here. I'd recommend that your bookmark this link to your favorites.
There should also be a "mini-manual" hidden inside the unit behind the control panel or in an envelope on the inside of the cover, which is very helpful when troubleshooting, & testing.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 05, 2009 | GE Microwave Ovens
Not Heating. Fan, turntable, light working.
I would definitely suspect the door locking mechanism in this case. If it was the sensor it would start and then stop within a short time.
The starter switch should click if you have the door open and time it for 01.seconds and press start. So that is the secon component to think of.
Nov 26, 2009 | Sharp R-930AK Convection/Microwave Oven
Microwave Ovens Logo
216 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
