Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
Alarm keeps going off; fridge freezer bosch KGU 3201GB/07
ALARM KEEPS GOING OFF
  • gemstac Aug 04, 2008
    It keeps bleeping and bleeping and is driving us nuts. Does anyone have a solution?
5 Suggested Answers
SOURCE: Freezer alarm keeps going off..
Mate prehaps the defrost element could be burntout thus no auto defrost and the big freeze and the alarm, when you switch off the defrost starts and the alarm resets?
Posted on May 03, 2008
22yooper
  • 828 Answers
SOURCE: When I come home the
Could be warning you that the condenser coil is in need of cleaning. Under front by toe plate or in the back under fiber cover. Vacuum out all dust and make sure the air circulation fan is running when the compressor is in operation.
Posted on May 15, 2008
22yooper
  • 828 Answers
SOURCE: The alarm on my fridge
It may be warning you that maintenance is in need. Check and clean your condenser coils . Under in front behind toe plate or in back behind removable fiber panel. Make sure the panel is replaced after you clean the condenser.
  • 958 Answers
SOURCE: frost free fridge freezer has
yes,
you have a defrost problem, three things..
one, defrost heater could be bad,
two, bi-metal could be bad,
and three, the timer could be bad.
any of these three items getting bad would result to one symptom.
ice buid up at the bottom of freezer section.
tnx 4 using fixya,
drcool
Posted on Aug 26, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Bosch frost free fridge freezer
The circuit board is fitted behind the display right at the top.
Unplug.
Open fridge, undo the two screws under the display moulding.
Using a thin bladed scraper and a flat screwdiver, prise the panel off at the top join. The top is the only bit with plastc clips, but it will help to apply pressure with the screwdriver at one end as well.
Pull it forward by about 2", and remove the connectors to the on switch.
There may be a drip strip to remove before taking the board out.
Use a thin screwdriver to remove the retaining clip over the board.
Use a small flat screwdriver to lever the board out using he holes at each end.
Observe anti-static precautions as it contains Cmos chips.
Reverse procedure to replace.
Posted on Dec 31, 2008
What do we do about a Westinghouse , vituoso where the freezer alarm keeps going off despite an expert checking and finding the fridge/freezer working perfectly well? Can the alarm be disabled?
The alarm is nothing more than a buzzer or light mechanism that is triggered by some sensor. . Disconnecting the wiring going to alarm will disable it.
Sep 25, 2015 | Westinghouse Refrigerators
2011 chevrolet tahoe security lockout... how do I reset it?
CAR ALARM ISSUES
It can be any of the car doors not got properly locked or the door is locked but the switch is not sensing the door locked. Open and close each door again properly.
Or else its problem with any of switch wiring getting in contact with alarm wiring causing it to happen.
And last thing alarm connections need to be inspected. It's getting short somewhere in between.
There are few help links with solutions, to troubleshoot these types of problems. I suggest going through these links.
Click the link below: ------
Volvo car alarm keeps going off for no reason
http://technoanswers.blogspot.in/2012/07/volvo-car-alarm-keeps-going-off-for-no.html
Alarm keeps going OFF
http://technoanswers.blogspot.in/2012/07/alarm-keeps-going-off.html
2009 Toyota Camry: Hood Switch causing Alarm to go OFF?
http://whatisbyme.blogspot.in/2012/04/2009-toyota-camry-hood-switch-causing.html
Ford Pickup Alarm will not disengage?
http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html
Mitsubishi Diamante: Factory Security Alarm will not go Off
http://www.howtorepairguide.com/2012/11/mitsubishi-diamante-factory-security.html
Toyota Avalon Factory Alarm will go off?
http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html
Chevrolet Tahoe Hood open warning on dash and alarm sounds?
http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
These details will help.
Thanks.
Nov 28, 2012 | 2001 Chevrolet Tahoe
I replaced a battery in my 2001 pontiac montana n the lights started blinking as if the alarm was going off.i hit the unlock n lock button n the blinking stopped. i have power,lights n radio but van wont...
Thanks.
Nov 28, 2012 | 2001 Pontiac Montana
Alarm goes off for no reason
It can be any of the car door not got properly locked or the door is locked but the switch is not sensing the door locked.Open and close each door again properly.
Or else its problem with any of switch wiring getting in contact with alarm wiring causing it to happen.And last thing alarm connections needs to be inspected.Its getting short somewhere in between.
There are few helplinks with solutions,to troubleshoot these types of problems.I suggest going through these links.
Click the link below:------Volvo car alarm keeps going off for no reason http://technoanswers.blogspot.in/2012/07/volvo-car-alarm-keeps-going-off-for-no.html
------------------ Alarm keeps going OFF http://technoanswers.blogspot.in/2012/07/alarm-keeps-going-off.html
--------------2009 Toyota Camry: Hood Switch causing Alarm to go OFF? http://whatisbyme.blogspot.in/2012/04/2009-toyota-camry-hood-switch-causing.html
----------------Ford Pickup Alarm will not disengage? http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html
------------Mitsubishi Diamante: Factory Security Alarm will not go Off http://www.howtorepairguide.com/2012/11/mitsubishi-diamante-factory-security.html
------------Toyota Avalon Factory Alarm will go off? http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html
----------Chevrolet Tahoe Hood open warning on dash and alarm sounds? http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
-----------These details will help.Thanks.
Nov 24, 2012 | 2005 Lexus ES330
My whirlpool frost free fridge freezer's alarm keeps going off, ice-cream doesn't freeze?
Check condenser is clean, fans working, thermostat set correctly, try to check internal temp with digital thermometer
May 17, 2012 | Refrigerators
Zanussi fridge freezer alarm keeps sounding
If the refrigerator and freezer are both working properly. Then the only problem would be the alarm, It's either the placement of the alarm thermometer or the alarm thermometer is stuck closed.
Mar 15, 2010 | Freezers
Bosch Fridge Freezer KGU3200GB/01 alarm beeping temp rising
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 26, 2010 | Freezers
Whirlpool fridge freezer alarm s20D RSB33AG-B
Hi, you have a common problem with your control boards; there is a cheap fix if you can use a soldering iron or you can have your modules repaired.
Let me know
bb
Aug 31, 2009 | Whirlpool Freezers
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
164 people viewed this question
Top Bosch Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Ken Thomas
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
