The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
you defiently have something wrong in the settings so don't worry its not wrecked check your settings check your zoom, and if that doesn't fix it take it to someone that knows alot about cameras so goodluck:) and please rate this solution...
Call your cable company as there might be a problem with the drop line or aerial coming into your house. now another thing is if you have a signal splitter( ex: 2-way, 3-way, 4-way) before the cable box, that could be degrading the signal as each input may drop the signal significantly. remeber, don't use too many splitters as they will make the signal faded/fuzzy. also, make sure all the connectors are clean and are not badly bent or the ends frayed. If you can see wire insulation from the cable line then it's no good.
Check if there is ample space on the memory and good charge on the battery and try, if it still persists then there is a fault on the lens moving out and in, probably because u wud have dropped it.
If you dropped the camera then the lense is out of alignment from when you dropped if mabey it can be fixed or not. It will cost much to fix the camera.it has a gear mechanisim so if its out of line its fuzzy pics.
My friend droped my camera and the lens is sideways. i can look at my pictures, but when i want to take a picture it is black and says lens error. what should i do?
make sure there is no flower icon on bottom left corner of screen-very common on sony to hit macro button to turn on by accident and you will get blur-only for extreme closeup-hit flower button to turn off if on and let me know if that was the problem
