Question about Dryers
REPLACE BELT ON SAMSUNG DRYER, MODEL DV4015J - Dryers
  • Anonymous Dec 01, 2008
    Same problem - dryer turns on, heats, but drum isn't spinning - do we need to change the belt?
  • Anonymous Dec 23, 2008
    how do we replace the belt on a samsung
    New Friend:
Here: Blu Products Unlocked Cellphones Great Value. I hope this was helpful. cheers
Posted on Nov 28, 2014
Take off the top of the dryer, the front of the dryer along with the ring thet holds the drum and the plate at the bottom backside of the dryer (there are alot of screws so make sure to keep track of them) put the belt on from the front side slip it all the way back (you will see a mark on the drum where the old belt was) go to the hole exposed from the removal of the back plate thet is where the tensioner is located. here is the part that got me, wrap the belt around the driver shaft pry up the tensioner DO NOT REMOVE THE SPRING IT DOES NOT MAKE IT EASIER put the belt under the idler so it applies tension to the drivertrack the belt and whalla you are done put it all together again and start drying. this is a ***** of a job but it is cheaper than getting a tech in to do it. i hope this helps
Posted on Apr 19, 2009
  • kawarthahill Jan 17, 2011
    thanks for the advise, seems pretty simple. i will try it tomorrow....many thanks.
  • 41 Answers
See:
http://www.fixya.com/support/t420249-samsung_dv4006j
Posted on Jul 01, 2009
  • Chris Goulet Jul 01, 2009
    Sorry, I meant to write this URL:
    http://www.fixya.com/support/t1210394-sa...
How do you change the belt on the drum
Posted on Aug 23, 2008
Control panel comes on but no noise and no turning when pushing start
Posted on Aug 18, 2011
2 Suggested Answers
  • 41 Answers
SOURCE: Re: Samsung DV4015J Dryer Belt Replacement
See:
http://www.fixya.com/support/t1210394-samsung_dv4006_dryer_belt
Replace the belt on pulley assemblyfor dryer dv4015j
There are plenty of YouTube videos on how to do this. The dryers are made by different manufacturers and are designed differently though. Watch the beginning of as many videos as necessary until you find one that comes apart the same way yours does. When you find that, everything inside will be the same too.
Jan 02, 2015 | Cars & Trucks
I am trying to replace the belt on my front load Samsung dryer model dv419aew/xaa
you will need to pull the top to gain acces to the control panel which you will remove to get to the screws on the front and go from there
Mar 24, 2014 | Samsung 7.3 Cu. Ft. Electric Dryer
My dryer does not spin. The dryer lights come on and everything works. When you press start the dryer does not spin and I hear a clicking noise in the back.
Your belt is most likely broken. YouTube "How to replace dryer belt" then add your make/model. They are all basically the same and pretty easy to change. The belt may run 20-25 dollars and will take about 15 minutes to replace.
Nov 01, 2011 | Samsung 7.3 Cu. Ft. Electric Dryer
Samsung dryer DV4015J turns on and motor sounds like its working but the drum does NOT turn so clothes do not dry, they just sit in dryer container?
If this is the older type, then the dryer drum is rotated by a thin loop belt that goes around the drum and then a pulley on the motor. I had to replace my 20 year old dryer belt on a Whirlpool a couple years ago. The front comes off and the belt slips over the drum. The front of the Whirlpool is held on by friction clips that have to be pried off with a flat blade. I suspect that you can do the same. look on the internet for a diagram of your dryer or you may have one in the manual that came with the machine.
Sep 19, 2010 | Samsung Dryers
How do i fix a belt that slipped off my samsung dryer model number dv448aew/xaa ?
There is a tensioner in the pulley that should keep the belt from slipping off.n most cases they work very well at keeping the belt tight.In your case the belt may be stretched too much ,I would check it and replace it if necessary
Mar 07, 2010 | Samsung DV448AEE Electric Dryer
Suggested Maytag belt incorrect?
are you sure that you have it over the idler pulley correctly and motor pulley in the correct order???if not youll have slack in the belt as if it were too long,call store where purchased and make sure belt is correct, they may have given you wrong belt accidentally and while your at it maybe they can show you a diagram of belt placement on your machine,only 2 things i can think of can be wrong
Jul 28, 2009 | Samsung 7.3 Cu. Ft. Electric Dryer
See:
Apr 13, 2009 | Samsung Dryers
Samsung dv4006 dryer belt
Possible replacement belt quality problem for the Samsung DV4006 / DV4006J / DV4015J / DV665JW and the Maytag MDE2400AZW dryers:
The original belt for the Samsung DV4006 / DV4006J / DV4015J / DV665JW dryers is a Megadyne 1975 H7. The part number is DC66-00121A, but when ordered, a Dongil 7PH1975 belt may be shipped instead of the original Megadyne. The Maytag MDE2400AZW dryer uses the same belt. The part number is 35001010, but when ordered, a Dongil 7PH1975 belt may be shipped. It seems that the Dongil belts are inadequate for these dryers. They delaminate and may fail prematurely. Even new, they cause a thumping sound each time the seam goes over the motor pulley. Other than Megadyne, another good belt is the Hutchinson 1975H7. The appliance part number is 1258288107.
Where to get an original Megadyne 1975 H7 belt:
eBay member 'appliance-parts' in Colorado, USA has emailed me that their Samsung DC66-00121A belts are Megadyne. Website: http://appliancefactory.com Email address: partsonline@appliancefactory.com
eBay member 'ladydi1975' in Ohio, USA has emailed me that their Maytag 35001010 belts are Megadyne. eBay store: Discount Appliance Parts.
Where to get a Hutchinson 1975H7 belt:
eBay member: 'zodiac300_0' in Brighton, United Kingdom. I have ordered a 1975H7 belt from them and received a Hutchinson.
Other possible causes for belt failure:
--Motor pulley designed too small. The belt may be flexed beyond it's minimum rated radius.
--Excessive heat in the dryer due to lint in the vent line or vent line too long. The Dongil belt may be less heat resistant than the Megadyne.
--Worn drum bushing DC66-00062A.
--Metal burrs on the steel motor pulley. Deburr by inserting a small screwdriver in each groove while the motor is turning without the belt.
--Belt on the wrong track. The motor pulley has nine grooves and the belt has seven ribs. The belt must be in the middle. It's easy to place it one groove forward or backward by error.
--Small scratches on the drum where the belt contacts it. The scratches may be like small knives and damage the belt. Sand with a fine sandpaper.
--Idler pulley damaged or bearing worn.
How to replace the belt:
--Remove top cover.
--Remove vent panel (in back).
--Unclip door switch from front panel.
--Disconnect wire harness from door switch.
--Unscrew panel left of control console (from behind the panel).
--Unclip panel left of control console (from behind the panel).
--Unscrew control console.
--Unclip plastic panel on bottom, front
--Remove screws behind door. Remove door.
--Unscrew large front panel, remove.
--Inspect vent line for lint buildup, drum bushing (back of dryer) for wear, motor pulley for burrs and debris, drum for scratches, and idler pulley/bearing for damage.
--Vacuum all lint.
--Install belt around drum, idler pulley, and motor pulley. The ribbed side of the belt contacts the drum. The flat side of the belt contacts the idler pulley. Press on idler pulley to stretch the spring, and line up the seven belt ribs in the center of the nine motor pulley grooves.
--Reassemble.
Nov 06, 2008 | Samsung 7.3 Cu. Ft. Electric Dryer
Dryers Logo
5,471 people viewed this question
Top Dryers Experts
