Question about Sony Cyber-shot DSC-W100 Digital Camera
Sony cyber shot dsc-w100
I dropped my camera in the water and when i went to take the battery out it turned on and off a couple of times with the lens going in and out. It is now closed. I have dried it out with a fan for a couple of days and when I put the battery in, light comes on but lens will not move. I tried to connect to my computer to get pics off the camera but nothing...help!!!
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey cocobear,
With any electronics water is their enemy, and if this camera was completely submerged it should be looked at by an authorized service technician. You could bring it to a Geek Squad® precinct in a Best Buy™ store and they could send it out to be looked at by an authorized service center. I will say that digital camera repairs often exceed the value of the camera. As far as getting your images onto your computer you could try taking the memory card out of the camera and try using a card reader that connects to a USB port and upload your images directly to your computer from your memory card. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jul 25, 2008
4 Suggested Answers
melnavz
  • 1226 Answers
SOURCE: Software for Cyber-shot DSC-W100
I think you DSC W 100 is windows xp compatible. However; you can download your software here: http://esupport.sony.com/US/perl/swu-list.pl?mdl=DSCW100&LOC=3
after downloading install it to your system.
copy and paste the link to the internet browser address bar.
Posted on Dec 26, 2007
kram26
  • 544 Answers
SOURCE: Lens problem
HI,
in your situation you need aproper tools to fix it and enough knowledge about the sensitive parts of your camera.
i prefer to suggest to you that instead of doing it by yourself bring it to a service to avoid and prevent any additonal problem that may occur.
thanks,
Posted on Jun 06, 2009
  • 11967 Answers
SOURCE: i dropped my sony cyber shot dscp93a the lens
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jun 04, 2010
Well actually my camera is a cybershot dsc-w100 and when i push the on button it says access but after that it goes to a mode where it says turn the power on and off again and i turn it off but still does...
Lens errors (access errors on Sony's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Oct 01, 2011 | Sony Cyber-Shot DSC-W1 Digital Camera
On my sony cybershot dsc-w100 the lens is stuck on the out position and it keeps saying turn power off and on again. it moves the lens and acts as if it is trying to retract it but it wont go in. I can...
Most of the lens issues due to mechanical problem. some of the causes are dropping the camera.
Hard shake like keeping the Camera in the hand and jump through steps, Moisture condensation, Insufficient battery.. etc If If you feel that the issue is not with the above reason. Remove the battery, reinsert after 2 minutes to perform a power reset and check the operation.
If the issue persists, service may be required.
Thanks for understanding
Jan 25, 2011 | Sony Cyber-shot DSC-W100 Digital Camera
Dsc-w100 window cracked/ no picture
sony cyber dsc-w100,not dsc-w55
I drop the camera and the window broke. where can I find a window.?
desilise
Dec 07, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-Shot 8.1 - when I turn the camera on the lens moves in and out several times and then it says to turn the power off and on again. Help
There is probably no user solution, it seems that optical lens block is wrong/damaged, the only solution is to replace it.
Oct 19, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Lens problem
HI,
thanks,
Jun 06, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Sony cyber-shot DSC-W100
I had same problem and found out after leaving the battery out for an extended time (4 hours) it totally reset and worked. The initialize function on the camera did not work.
Dec 08, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
My Cyber shot DSCW35 SAYS THAT TURN THE POWER OFF AND TURN ON AGAIN
Yes, that never works does it? =] A better error message would be "Replace jammed lens please! ", since this is the cause of the error almost 100 percent of the time.
Nov 12, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
On and off
camera will do this if batteries are weak. If you have fresh good batteries and or charger on camera and its still doing this..Then lens need replacing .
Dec 02, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Sony Cyber-shot DSC-W100 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
