Question about Emerson Microwave Ovens
1000W Microwave Oven Will not quit running when the door is closed. The only time it will quit running is when the door is opened.
  • Emerson Master
  • 19,396 Answers
It is the timer broken
Posted on Jul 25, 2008
Why microwave starts whenever door is opened ?
The micro-switch is loose. Get inside the oven and look for the micro switch and either adjust or replace it.
May 28, 2014 | Emerson 1000W 1.3 Cu. Ft. Microwave Oven...
Why does my microwave keep running/heating until I open the door? what can i do about it?
Sounds like a problem with the control panel. Further diagnostic testing would be required, however, as there can be other causes.
May 10, 2014 | Oster OGB61101 Microwave Oven
Light stays on
Possible that the door switch is stuck or that the relay is jammed within. Remove the power and gently tap on the door switch and the relay on the PCB.
If there is no result and if there is no switching of the microwave unless the door is closed , then problem can be due to the control board.
Jan 11, 2013 | GE Profile PEB1590 1.5 Cu. Ft., 1000W,...
Just quit working
I assume there is no display at all. First make sure there is power to the microwave. Next would be the fuse INSIDE the control section. It needs a 15 Amp slow blow fuse. If that is the problem and you replace it (first disconnect oven!) and the oven works Ok that sould have taken car of your problem. However to do a little test you could, after having replaced the fuse, open and close the door several times. If it blows the fuse again that means that there is a problem with the door switch sequence. I don't know if you want to go this far, but there is one "normally closed" switch that, when closing the door, needs to open before the "normally open" switches make contact. Conversely when opening the door the "NO" switches need to open before the "NC" switch makes.
May 08, 2011 | Microwave Ovens
My microwave will not shut properly. The top latch will not completly close. The microwave still runs... but It will not heat food and it makes a clicking noise. Can this be fixed or should I purchase a...
Hi, quite often this is due to a bad door switch located inside behind the area where the door hooks go into the oven.
Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure.
In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see from time to time, and we repair those nationwide for $32.50, but it's usually a door switch.
It can be fixed......
Apr 28, 2011 | Whirlpool MH2155XP Microwave Oven
My microwave lights blinked off right after i closed the door after checking meal and re-entering time. i unplugged it and tried a different socket nothing happens no sound lights for time or inside the...
I suspect the interlock monitor switch in your microwave oven is the culprit. This is one of several switches operated by the door latches. It's designed to blow the fuse if you try to run the microwave with the door open. The switch is probably stuck, or is out of adjustment (which can happen if the oven door gets closed hard), and when you restarted the oven it blew the fuse. It is possible to adjust or replace the switch as necessary, but it might not be worth it. You should have a professional do the repair as there's a chance of microwave leakage if repairs involving the door aren't done properly. Between labor and parts, the repair cost might come close to (or even exceed) the replacement cost for a small oven.
Hope this helps, and thanks for using Fixya!
Nov 09, 2010 | Emerson MW8778 Microwave Oven
Microwave continues to run when the door is closed
Did you pressed the stop/clear button? or disconnect the micro.. for a couple of hours and try again?
Apr 04, 2009 | Microwave Ovens
Microwave oven
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: You can find helpful exploded view diagrams and order parts by entering your model number here: Feel free to contact me directly if you have further questions. I appreciate your thoughtful rating of my reply.
Oct 02, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
66 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
