Question about Kitchen Ranges
F1 error code on comp screen of wall oven - Kitchen Ranges
  • 4 more comments
  • Anonymous Jul 30, 2008
    When I turn the oven on, it starts for a while, then the error code comes on. The clock works ok. I turned the circuit off for two days and when I turned it back on, I got a F-3 code, but after that, it has been F-1 codes. How much does the ERC cost? I hope I'm not being a nuisance but when you are retired and living on a fixed income, you must try to save every penny you can. A word for the young, work hard and save while your young because age catches up to you before you know it. Thank you very much for whatever answer you can give me. God Bless, George Nieves
  • Mel Bell Aug 02, 2008
    I just moved into a house with this stove and when the stove is turned on, I get an F1 error code and it beeps once a second. I need help!! Thanks in advance.
  • Radddanny Aug 14, 2008
    F 1 code is on my oven what do I need to do?
  • RJSANNA Oct 14, 2008
    OVEN WILL NOT SHUT OFF. GETTING F1 CODE RIGHT AFTER COOKING DINNER.UNPLUGGED IT,AND RECONNECTED,STILL THE OVEN WILL NOT SHUT OFF
  • us329408 Oct 14, 2008
    oven stays on, even after unplugging and replugging. F1 code. Where do I find the solution?
  • hansonsb Dec 13, 2008
    same thing f1 code have used the oven for about a year have unpluged it several time and pluged it back in still f1 code. they say it is a erc cost about 275 plus service call and labor to fix. paid 850.00 for this stove thought it was a good one.
The solution is people to find yourselves a better website-this one is full of problems and no solutions!!!
Posted on Feb 19, 2009
  • 218 Answers
For a KitchenAid electric wall oven, error code F1 means the electronic range control (ERC) has failed and needs to be replaced.
Posted on Jul 25, 2008
I have the same problem. We just moved into a house and the stove was unplugged, we plugged it in and to my horror, our ears kept ringing from the horrible beeping noise that sounds like a smoke detector going off. We have a GE JGBP31/34/35 GEP
We phoned GE and found out that since we cannot clear the F1 message, that we have to replace the ERC....which means the entire computer unit in the stove. We spoke to the parts department and the cost for just the part for our model is $391.65 (CAD) plus tax, shipping & labour. Might as well buy a new stove!
We cannot use the oven and only can use the burners while the stove is beeping.
Posted on Mar 09, 2009
What does it mean for screen to flash f1
Hello friend, thanks for your post!
From my understanding your Frigidaire range is displaying an "F1" error code. "F1" typically means that your wall oven has detected an issue with the runaway temperature (overheating). Sometimes resetting your appliance can correct this issue but in the case that it does not and you still receive that error code I would recommend having a professional come out to properly diagnose and repair. At that time you could be having an issue within RTD (Resistance Temperature Detector) sensor probe or the EOC (Electronic Oven Control) having a professional come out would reduce the cost of unnecessary parts. Hopefully this has been helpful. -Matt
Oct 12, 2014 | Frigidaire Kitchen Ranges
Whirlpool wall mount oven won't heat at all. Error code E3 F1
Technical sheet says all F1 codes to replace control
Jan 17, 2014 | Whirlpool Ovens
I have a frigidaire wall oven showing E r r f1 what is wrong no manual
Typically error code F1 could indicate a variety of issues. The wall oven could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the wall oven by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately
Nov 19, 2012 | GE Ovens
F1 code GE profile convection self clean wall oven (95?) oven beeps F1 code oven works when it is on bake etc. when touch key are pressed it goes off but starts to beep again
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Sep 19, 2011 | Ovens
I got a GE double wall oven and when I turn the oven on code F1 comes on
Hi
Daniel
Aug 06, 2011 | GE Built-In 24" Double Electric Wall Oven
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
I have a frigidaire model cfeb786jgb3 error
f1 is a watchdog on the control board
replace control
Jun 30, 2009 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire gas wall oven clock unit sometimes says F1 and beeps.
F-1 is USUALLY a touch pad error, it thiniks something is stuck. The sensor error code is F-3.
Mar 17, 2009 | Frigidaire 24" Built-In Single Gas Wall...
GE Wall Oven - error code F1
According to GE, the F1 fault code indicates a problem with the Electronic Range Control (ERC) Board. If the fault cannot be cleared, they recommend replacing the ERC and the touchpad. Has your repair guy tried any of these ideas? Post back with your comments, please.
Jan 17, 2008 | Kitchen Ranges
Dacor cps130 wall oven f1 error
According to the manual, this is an element relay circuit failure. Call the tech.
Dec 04, 2007 | Ovens
Kitchen Ranges Logo
920 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
