Question about Motorola Mobility RAZR V3
Light not working
The light in the keypad underneath the numbers doesn't come on when the power is on.
  • 1 more comment
  • Anonymous Dec 20, 2008
    the same...the light wont come on any more
  • Anonymous Dec 22, 2008
    I have a motorola razr and the key pad does not light up. it just recently stop. the phone works good in every other aspect.
  • ortegad61 Dec 22, 2008
    I have the motorola razr and have a problem with the key pad lighting up. it just recently stopped working. everything else on the phone works fine.
The backlight is burnt.
Posted on Jul 25, 2008
Start enter button not working
If you know how to repair microwaves, see these youtube tutorials:
Fixed microwave number pad
Quick repair GE microwave touch control key panel doesn
Samsung Microwave SE 5E Error Fix
Lg Microwave keypad repair
No light? You can look for more videos or take it to a repair shop
Jul 13, 2015 | Microwave Ovens
Tappan 5030 microwave oven fuse is ok but no lights on keypad come on
see the causes and fix it. God bless you
Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 10, 2012 | Tappan TMS062E1 Microwave Oven
GE Microwave Model: JVM1540DN1BB Keypad appears to work... but Microwave doesn't work
The problem is more than likely in the microprocessor control board, sometimes a bad relay, or poor solder points.
Mar 11, 2012 | Microwave Ovens
How do i unlock my lg 8600 flip
  • Flip open the phone so the keypad is exposed and press any button to wake the phone up from sleep mode.
  • 2 Enter the four digit unlock code using the phone's keypad. The default code is the last four digits of your cell phone number.
  • 3 Press the "OK" button to submit the code and unlock the phone.
Forgotten Code
  • 1 Turn the phone over and remove the battery cover and battery. Press down on the upper plastic edge of the cover and slide it in a downwards motion. The plastic cover will give way to the battery which can be pulled out of the phone.
  • 2 Locate the sticker on the phone hidden behind the battery. Write down the last four digits of the ESN DEC number.
  • 3 Replace the battery and battery cover and turn the phone on by pressing and holding down the "Power" button.
  • 4 Flip open the phone so the keypad is exposed.
  • 5 Enter the last four digits of the ESN DEC number. Press the "OK" button to submit the code and unlock the phone.
Power the phone on and select the "OK" button. This will trigger the phone to ask for the password.
  • 2 Press "OK." Sometimes this is simply all it requires. If not, move on.
  • 3 Enter the last four digits of the phone's number. If this doesn't work, continue to the next step.
  • 4 Enter "#4357" or "*4357." "4357" stands for "LOCK" on a traditional telephone's alphabetic keypad translation. This is the default unlock code for certain LG telephones.
  • Dec 06, 2011 | LG Cell Phones
    The letter keys amd number keys do not work
    Could be a bad keypad or possibly a motherboard problem.I would try another keypad first if that doesn't work look to the motherboard.
    Nov 16, 2011 | Acer Aspire One Netbook
    Some keys not working on my sharp xe a130
    If you are able to open your keypad get to it and look at the bottom of the keypad. You must identify those keys that do not work. You shall see that underneath the keypads there is some black round stuff that is sealed there for contact. What you do with the keys that won't work, you must clean the surface with damp cotton wool. If this doesn't remedy the situation then get an old pad of a desk calculator. If you carefullly cut a thin slice of the black material and seal it against the key that's not working using good contact adhesive. Try this and see if works for you. It worked for me.
    Oct 22, 2011 | Sharp XE-A404 PC Desktop
    Why is it the lights are not on my keypad
    GO TO DISPLAY SETTINGS THEN CHECK FOR KEYPAD LIGHTS AND ACTIVATE IT......
    Oct 20, 2011 | Cell Phones
    My number keypad has stopped responding how can i fix it please
    Hello and Welcome to FixYa!
    If your numeric keypad is not working please first make sure that the numeric lock button (may be a light too) are on. Try to press the numeric lock button once and then use the keypad. If this doesn't work try pressing it again.
    If you have any further queries, please do not hesitate to comment again. If this solution was helpful to you, kindly rate it.
    Regards, Waqar.
    May 22, 2011 | Computers & Internet
    The problem i am facing with my new nokia E75(BLACK SILVER) is that,it's keypad light doesnt gets on while dialling the number,,,,i am not talking about the QWER keypad but the normal alphabetical...
    The Phone is fine all keypad lights only come on when you are in a dark place it works on a sensor I assume this is a feature created by Nokia to save battery power
    Oct 27, 2009 | Nokia E75 Cell Phone
    How do I use Dell inspiron 1300 keypad?
    If you are referring to the Number keypad.
    Tap the "Num lock" key and you will see a light flashing.
    Make sure the light is on when you stop.
    Now try the keypad.
    Mar 15, 2008 | Computers & Internet
    Motorola Mobility RAZR V3 Logo
    190 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    vince
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
