I have just conneceted my samsung dvd recorder to tv model dvdr155. when i put my disc in it comes up on my tv system error then it says it want intialize disc .help
You have to initialize disc to be able to record, according to my experience.
Posted on Aug 24, 2008
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
Will not record on blank dvd and rejects some saying disc error
In the past, when that occurred to me, I either had the wrong type of DVD disc or it called for a unused DVD disc to be put in. Be sure you are not using a CD disc.
Oct 29, 2010 | Samsung DVD-VR330 VCR and DVD Recorder
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I can't watch a DVD +R on my computer only in a Samsumg dvd playe
it may be that your dvd player may not be able to read dvd+r discs. not all do ,please check your dvd player has the capabilities of reading dvd+r discs.
i.e have you ever watched a dvd+r before on your dvd player?
if it does try getting the model number of it.
May 19, 2009 | Computers & Internet
Samsung DVD-VR320 DVD wont record and shows EC0509
Try cleaning the lens. A commercial lens cleaner should do the job, but if not, contact me again, and I'll try to help you clean it manually
Jan 04, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
Direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
Nov 20, 2008 | RCA RTD155 System
The Samsung HT-Z310T is a DVD player, not a recorder, that is why you are getting an error when inserting a blank disc
Sep 01, 2008 | Samsung HT-Z310T Theater System
Will not playback get error message Please Check Disc
i have a r136 , have you got the dvd discs u need ? i had the wrong format .
eg, dvd+rw needed dvd-rw
if not and there re-recordables they dont work after a few recordings and u need a new disc.
Dec 05, 2007 | Samsung DVD-R130 DVD Recorder
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
DVD Camcorder appears to have erased disc mid record!
I know it won't play in a dvd player till it is finalized. Leave it in camera mode, hit menu, and scroll down till you see the option to finalize. If you finalize it, it should play in a dvd player. I am having a problem with my camera(same model) where it won't finalize the disc. Any help out there?
Nov 16, 2006 | Samsung SC-DC164 DVD Camcorder
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
