My husband has a hp flatscreen monitor that has malfunctioned the last 2 times he has shut his system down. When he starts it up, the monitor keeps flashing every few seconds, the full screen of his desktop does not completely display. Is his monitor on the way out? I hope not. After 5 or 10 minutes it does fully appear and is operational but he's afraid that that won't always be the case.
  • edholly Jul 25, 2008
    no, the monitor does not shut the computer down. He has turned the whole system off due to severe thunder storms. Then when it's all clear (the weather), he turns everything back on. All is fine when he reboots the comp. except this glitch with the monitor.
    Problem Solver:
  • 6 Answers
I'm confused by your phrasing; the monitor turns off the computer itself?
Have you performed a virus/spyware/malware scan recently?
Posted on Jul 25, 2008
  • chris12321 Jul 29, 2008
    I'm assuming you're using a VGA connection on the monitor (the blue plug), am I correct?
    If you can, try to use a different power cord and VGA cable to connect to the monitor; it's possible that something is wrong with one of the connections on the VGA cable.
    Make sure the ports on the computer and the monitor are clean and clear of any dust or debris that may interfere with the connection.
    If you can, try to use a different monitor in this scenario to see if it is indeed the monitor that needs replacing. Connect another monitor and power off your computer, and restart everything to see if your monitor is any good.
    I hope that this is of help! =)
How do I troubleshoot an unresponsive HP LCD monitor?
The easiest thing to do is find another monitor to plug in to determine if it is the monitor or the computer. Just because something has been stored does not mean that something fried the first time you plugged it back in. LCD monitors are notorious for having bad capacitors.
Nov 10, 2014 | HP DeskJet Office Equipment & Supplies
I have a 2000 buick century custom 5.1.... my car keeps throwing the evap and catalyst monitor and once I start getting low on fuel my engine light comes on and it shows 2 codes for P0440 evap and P0330 (I...
P0330 Knock Sensor #2-Circuit Malfunction (Bank #2)P0440 Evaporative Emission Control System Malfunction.http://www.autozone.com/autozone/parts/Duralast-Knock-Sensor/2000-Buick-Century/_/N-je30qZ93xni?itemIdentifier=136530_0_0_
Nov 08, 2012 | Cars & Trucks
IBM 8303 DOESN'T SUPPORT MY FLATSCREEN HP VS15
2 steps:
1. plug the hp vs15 into another computer and see if it works, if not could be a bad monitor.
2. If you have the old monitor, plug it in to the IBM computer and in windows lower the resolution down to 640 X 480. Now turn off the computer and plug in the VS15 monitor. If resolution was an issue it should work now.
Hope this helps
Jan 31, 2012 | IBM Computers & Internet
Hyundai Tucson a/c starts out cold air then starts to blow hot air then goes back to cold air
The issue you describe can be caused by several possible conditions. The best advice I can offer is take the vehicle into an authorized Hyundai Service Department to have it properly diagnosed.
The worse thing about chasing parts is you may or may not just get lucky on the repair. Then again you may end up shelling out $100's of bucks before you actually hit on the cause.
Possible Causes
1. Malfunctioning thermostat in the evaporator - monitors evaporator temperature so it doesn't freeze over.
2. Malfunctioning A/C control head (panel)
3. System is possibly UNDERcharged (insufficient refrigerant)
4. Malfunctioning Tripple Switch (the switch monitors pressure in the system: i.e., if pressure is too high, it will shut down the A/C; if pressure is too LOW, it will shut down the A/C) If this switch is malfunctioning, it can cause the symptom you describe.
5. Engine Coolant Temperature Sensor malfunction - if the sensor is lying, telling the engine computer that the temperature of the engine is above 230 degrees, the computer will shut down the A/C.
This is why you should have the problem properly diagnosed.
Hope this helps.
Jun 28, 2011 | 2006 Hyundai Tucson
Every time i turm my computer on the monitor comes on and then says going to sleep the computer shuts down will not stay on. I can"t do anything, it keeps shutting down and the monitor shuts down.
this is a computer problem not a monitor problem whens the last time you cleaned out the computer as in air blasted to clean out any dust if the power supply over heats this would cause a shut down the other thing would be a problem with the mother board open case look at the stuff inside and see whats dirty cpu, power supply , motherboard dust a #1 killer of motherboards
Dec 10, 2009 | HP Media Center M1050Y PC Desktop
My monitor keeps shutting down while my system is still running and I have to manually shut down my tower. This will happen anywhere from 1 - 10 times in an hour.
Check your power supply, check your RAM and make sure it is dust free. Cleaning of system is recommended. Or there is case that you might need to reinstall your windows if nothing helps.
Nov 14, 2009 | HP Compaq FS7600 17" CRT Monitor
Windows XP powers down the monitor after a few mins running.
ok theres a simple solution u need to decide to yourself when was it working last then click start\all programs\accessories\system tools\ststem restore and restore your computer to a time when it was working...backup your recent files because u will lose them and if it still doesnt work you may want to do full system restore. what it does is brings your computer back to the state it was in when you bought it but you lose evrything how you do that is press f8 while booting before your OS loads
Jun 06, 2009 | HP Computers & Internet
My new 21' flatscreen monitor keeps shutting off :(
Usually when an LCD display shuts off on it's own this can be a power supply issue. I would say if you checked all the connections you may want to contact the manufacturer. If it is only a few months old then you should be able to get it replaced under warranty.
Also, you may have an auto shut off feature enabled on the display itself. You may want to go through the display's menu to very that this is not the case.
Mar 08, 2009 | HP Pavilion F1703 17" LCD Monitor
No DVi input, then computer goes to sleep
I have a new HP pavilion slimline with Vista......a 19 inch flatscreen monitor......I went nuts with it not connecting and saying no DVI input......
I tried something and so far it has worked 10 times in a row...
start out with puter and monitor off.......turn on monitor.......let it go to sleep....then turn on puter....
I have the puter that has the start button on top of it.....not too crazy about it.....
hope this works for you.........Judy in NY
Dec 07, 2008 | HP 22" Widescreen Flat Panel TFT LCD HD...
HP flatscreen not powering up
1 situation - No leds? No menu on screen?
Take it to a service provider for repair.
2 situation - Leds on, menu on screen.
No video in your computer. Ask help for your computer.
Dec 17, 2007 | HP Pavilion F1703 17" LCD Monitor
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
