Question about Star Logic 17" LCD Monitor
Havea lot of lines on monitor
Hi,my starlogic 19" moitor works fine about 1 month and after that when turned it on I see a lot of lines,on few first days it showed lines and auto came back to nomal,but now everytime I turn it on ,all monitor show many tiny lines.Can someone know what happened and how to fix,I really like this monitor, it has great shape and very nice picture ,video.Thank you so much
    Problem Solver:
  • 6 Answers
Theres a adjustment on flyback they have two adjustment screen.if you made an anjustment turn off the monitor the adjustment anti clockwise little bit.
by the way my name is robert im technician all branded name of sony, jvc,philips etc....
Posted on Aug 18, 2008
My Starlogic monitor fails to power up. We had a recent power outage. Everything else on the computer seems to work properly however when I power up the pc the monitor will not turn on. Have manually...
Not sure if you have done this so give this a try.
* If possible, plug your Starlogic monitor into another working computer. If the Starlogic monitor works then it is the port on the original computer that has gone bad. The solution would be purchasing a new video card such as PCI or AGP video card. (Assuming all other aspects of your PC are working fine)
*However, if the monitor does not work then you know your monitor is dead. You will need to buy a new or used monitor. **You may want to barrow someone's monitor and test your original computer just to make sure the port on that original computer is fine.
Jun 16, 2010 | Star Logic 17" LCD Monitor
When I first turn on my computer, my Starlogic
An internal component failure inside the monitor, replace the monitor.
May 12, 2010 | Computers & Internet
Starlogic 19" flat panel screen won't show anything.
Have you made sure that all the cable connections are screwed in tight?
You could also remove the cable to make sure that none of the pins have become bent out of place.
Sep 11, 2009 | Computers & Internet
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
17'' monitor whte screen power light on
have a 17'' starlogic flatscreen monitor and i opened a game and it went to white screen and stayed there.
Jun 19, 2008 | Star Logic 17" LCD Monitor
Starlogic LCD Computer Monitor
I can't find a website for StarLogic anywhere, so either they have gone out of business (not likely as there should be some reference to them somewhere) or they are imported from a foreign manufacturer and rebranded with the StarLogic name.
May 13, 2008 | Star Logic 17" LCD Monitor
Won't Turn On
Hi
If the green light doesnt turn on, check if the wall outlet is workign properly.
Also pls check with another moitor power cable.
If the above steps dont work, then the monitor needs to be serviced.
Jan 14, 2008 | Acer AL1912 19" LCD Monitor
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
Push button power broke Starlogic LCD 19"
My monitor Display show to wide.
Starlogic 19'
Nov 07, 2007 | Star Logic 17" LCD Monitor
Star Logic 17" LCD Monitor Logo
131 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
scj103
Jerry Umali
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
