Question about Whirlpool Washing Machines
Whirlpool washer model #LST8244AQ0 - electrical power went out while washing - fuse blew - washer would not go back on - timer knob moves but machine will not agitate or spin
the dr
  • 447 Answers
SOURCE: whirlpool top load washing machine - agitator
There are gears inside the agitator that are very cheap and relatively easy to change they are called agitator dogs. Dont forget to rate my solution as solved if i answered your question accurately.....Thanks!!
Posted on Oct 01, 2007
Oceti
  • 51 Answers
SOURCE: Will not drain or spin
Unless you jarred the machine it's the timer. You can check this by bypassing the lid switch and seeing if it will cycle.
Posted on Dec 13, 2007
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
  • 112 Answers
SOURCE: washer won't spin
The first thing I would check is if your timer is advancing. Set it at th beginning of a wash cycle and let it go. See if the timer knob arrow advances. If it doesn't, your timer is bad.
Posted on Oct 18, 2008
ginko
  • 19396 Answers
SOURCE: Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Posted on Nov 20, 2008
    Stat button
    see this steps and fix it. GOD BLESS YOU
    User Control and Display Board
    If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
    Enter your model number to see parts for your washing machine.
    Help me find my model number
    Timer
    If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
    Line Fuse
    If the washer won't start the line fuse might have blown.
    Thermal Fuse
    If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
    Line Fuse and Holder
    If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
    Main Control Board
    If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
    Door or Lid Latch Assembly
    If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
    Door Lock Motor and Switch Assembly
    If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
    Incoming Power Problem
    If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
    Power Cord
    If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
    Jul 21, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
    I want to replace a timer on a Whirlpool washer Model# LSN1000KQW
    Good day Mr.james dant..
    Whirlpool manufactures many types of washing machines. Whirlpool's top load models rely on an analog timer that controls the cycle used to wash the clothes in the washing machine, rather than a digital control board found in most front load models. The timer contains a number of moving parts and is physically turned to choose the wash cycle. Because of the high usage of the timer, it will eventually break, requiring replacement. Rather than calling a service technician to repair the timer, replace the timer yourself to save both time and money.
    Instructions
    1. Unplug the washing machine from the wall outlet
    2. Turn the dial to the "Off" position and then unscrew the knob from the timer. To unscrew, hold the dial with one hand and turn the knob counter-clockwise.
    3. Lift the dial off of the washing machine.
    4. Remove the two mounting screws securing the timer into position. 5. Remove the two screws from the bottom left and right sides of the control panel, then rotate the control panel up 180 degrees.
    6. Remove the wire harness from the old timer and remove the old timer
    7. Connect the wire harness to the new timer.
    8. Place the timer into the control panel. Hold the timer post with one hand and rotate the control panel back down. Secure the timer into place using the mounting screws that were removed from the old timer
    9. Place the dial back onto the timer post and then screw the knob onto the post.
    10. Plug the washer back into the wall outlet
    Try to watch this video:
    Nov 25, 2011 | Washing Machines
    We need to replace the timer, how do yoy get the main wash cycle knob off the machine
    First, see the following for how to release the console for access to the timer:
    http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=5cac791c099cfeceeefa8f469d527d82
    If your washer doesn't have end caps that come off, try slipping a thin putty knife under the edges of the console from the front to release the clips.
    Then see the following Whirlpool / Kenmore Service Manual for top load, direct drive washers:
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
    You'll have one of two different timers.
    If you have the normal one, hold the shaft that goes thru the timer with a thin needle nosed pliers and unscrew the timer knob.
    Once the knob is off, you only have to disconnect the electrical leads and the bolts holding the timer in.
    Also see the Sears parts site for your washer:
    http://www.searspartsdirect.com/partsdirect/index.action
    Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
    Dec 04, 2010 | Kenmore 24032\24036 Top Load Washer
    Removeing timer switch knob
    This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
    First, see the Sears parts site for your washer:
    Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
    See the following for how to release the console:
    http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=d09053515715195798276a5664b79cf0
    Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
    If this is a basic top load, direct drive washer, these units may have one of two different timers. (See the Whirlpool PDF).
    On models with a metal timer, you have to release the console, pull it forward and tilt it back in order to get to the back of the timer.
    The knob screws onto a medal shaft that goes through the timer.
    Usually, trying to un-screw the knob won't work by itself since the shaft will also turn.
    I found that if you hold the back of the shaft with a thin needle-nosed pliers, you can unscrew the knob.
    Then you simply have to disconnect the timer.
    The Whirlpool PDF also has troubleshooting and testing procedures for the timer.
    Jun 08, 2010 | Kenmore 24032\24036 Top Load Washer
    The start/ stop knob of my whirlpool washer LSQ9564JQ0 just spins. I have to deeply press against the larger part of the timer to move the arrow to the wash settings. I will still start and stop though....
    The threads either on the timer knob (part number 3364291) and the timer dial ( Part number 3957849, the larger part of the timer with arrow) are worn. Pull the knob off and inspect the threads. Replace the part with the worn threads.
    Jun 08, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
    The machine suddenly "clicked' when I took laundry out and seems "dead"- Is it switch possibly pannel switch that stop working? When I rrotate knob and pull it out- no response- no electricity and no...
    The control board went bad. Your switch went bad or you blew the fuse. All are located behind the knobs. Just remove the knobs and undue the screws up top. Make sure to unplug the system before opening it up
    Jan 02, 2010 | Maytag PAV2300 Top Load Washer
    Washer does not change cycles on its own
    timer is most likely bad if it will not move on its own at all..
    3951703 - TIMER
    you can access the timer by:
    remove power from the unit.
    remove the philips head screws that should be present in each left and right control panel end cap front.
    slide the control panel bottom forward 1/2 inch and lift up.
    the entire console will swing up on the hinges in the rear of the console top.
    with the console upside down you can see the back of the timer, there is a small brown clip sort of recessed into the back of the timer that is connected to the timer knob/shaft. that clip needs to be pulled out so that the knob can be removed to access the screws on the front to remove the timer assembly.
    around $100 new
    hope this helps,
    best of luck,
    ttfn
    Oct 25, 2009 | Whirlpool Washing Machines
    Washer Doesnt Change Cycles
    Enter your model number and you'll see a list of major sub-components with diagrams and parts.
    This appears to be a timer / timer motor problem.
    I'd alto look at the Whirlpool / Kenmore direct drive installation and maintenance manual for testing the timer.
    Sep 26, 2009 | Kenmore 24032\24036 Top Load Washer
    Whirlpool washer will not spin
    sounds like the timer is shot.
    Apr 30, 2009 | Whirlpool Washing Machines
    Washer won't spin
    Oct 18, 2008 | Whirlpool LBR4121JQ Top Load Washer
    Washing Machines Logo
    90 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
