Question about LG WM2688H Front Load Washer
FUll of Bubbles and won't drain
I opened the compartment on the lower left and turned what I thought was the filter to remove it but water is pouring out non-stop. How do I get the washing machine to drain and if I am supposed to turn that filter on the bottom left, how long until it stops pouring water - I've soaked 5 towels completely.
  • 706 Answers
That is the filter compartment that you accessed. I believe ( and you can verify ) that there is a short hose with a cap next to that filter that you can extend to control the drain off into a container or two. If you haven't cleaned the filter for a long time, there is a good chance that it is blocked up with junk that limits the system from draining properly. I had that problem myself. Also, these front loaders use HE detergent and Ihad been filling the detergent cup up to the mark but you because these use very little water during the wash cycle I was advised to use only a few drops... Yes drops.. and I have been and clothes come out just as clean. maybe even a bit less if you buy X2 or X3 HE detergent. Hope my bad experience with this helps you...
Regards
Posted on Jul 25, 2008
We've had a Cuisinart DCC-2000 coffee maker for less than a year: 1) it stops brewing about halfway through the brewing cycle (with plenty of water still in the reservoir, and 2) the "Clean" light
This problem is caused by a clogged water filter in the unit.
Unplug the coffee maker.
Open the top panel where you normally pour in the water and set the coffee filter.
Gently pull up on the tap that sticks up in the back left corner of the open top. This will free a long plastic part that has a compartment at the bottom that contains a filter filled with charcoal.
Unsnap the small compartment that holds the filter and clean it gently under running water with light brushing.
If there is a lot of coffee build-up, the water chamber where you normally pour in fresh water needs to be cleaned out. Pour in a cup of water and invert the unit over a large sink pouring out the water through the opening you normally use to fill the unit.
Repeat this until you remove the coffee grounds.
Let the unit dry fully before plugging in to run again.
Sep 30, 2012 | Cuisinart DCC-1200 Coffee Maker
Our Haus hw50-1010w washing machine won't drain and seems to keep repeating the cycle. We cant open the door and it is full of water -please help!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 03, 2011 | Washing Machines
I have an electrolux top loader model EWT 806 and the lid won't open even have tried to turn it off still won't open please help thanking you
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
John C
Jun 16, 2011 | Electrolux Washing Machines
I select a wash cycle and it begins to wash display lit up and finishes washing then display has two lines lit and won't continue to go to spin cycle. can turn power off and on ,press spin cycle and...
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
John C
May 12, 2011 | Washing Machines
Clogged up. Washed rubber backed rugs and the rubber shredded. It wont drain. How do I clean it out?
¡æThe drain pump filter
The drain filter collects threads and small objects left in the laundry. and rubber from rugs
Check regularly th
1. Open the lower cover cap
with a tool such as coin.
Turn the drain plug to pull
out the hose.
at the filter
Unplug the drain plug ,
allowing the water to flow out.
At this time use a vessel to
prevent water from flowing
onto the floor. When water does
not flow any more, turn the
pump filter open to the left
is clean to ensure smooth running of your machine.
Remove any foreign objects from
the pump filter . After
cleaning, turn the pump filter
clockwise and insert the drain
plug to the original place.
Close the lower cover cap
Dec 20, 2010 | LG WM-2277HW Front Load Washer
Water leaking inside
Hi,Open the freezer compartment, unsrew the two nuts. pour a little warm water to defrost the bult up ice on the freezer compartment. At the estreem end, a shining drain pan might full of iced remove the ice at the center of the pan you will see a hole blocked with ice, pour hot water on it till all melted away. open the back of your refrigeration there is a water drain hole, around the left hand corner. see if the hot water driping off. this resolve the problem.
Thanks and Good luck
Jun 04, 2010 | Maytag MTB2176 Top Freezer Refrigerator
Water leaking from the bottom of frig
Your  deforst drain is clogged.  Every 12 hours or so your fridge does a deforst cycle.  It melts all of the ice built up on the evap coils.  There is a drain at the back of the fridge that goes to a pan by the compressor where the heat from the compressor and the condensor coils evaporates it.  Take the back panel off of the freezer compartment and plunge out that hole.  You will most likely have a build up of ice over the top of the drain.
May 30, 2010 | Maytag MSD2454G Side by Side Refrigerator
Water in refrigerator
You will need to remove the back wall in the freezer compartment. Once you have removed the back wall you will see ice build up in the drain trough area. Using a hair dryer you will need to remove all of the but be very careful not to damage the soft metal of the evaporator coils. After removing all ice you will be able to see the drain hole which will also have ice build up. Melt this ice also. A good way to help with the drain ice is to heat water to a boil. About a cup full and then pour little at a time letting it set for about 2 minutes then dry as much as possible and then pour little more. Keep repeating till water flows freely. Slow process but this will take care of your problem. Thanks and good luck. Rick
Feb 27, 2010 | Refrigerators
Why can i not get the dryer to work? error E20 is flashing.
HI,
Can you hear the pump trying to drain it when you start a cycle? If not it needs a new pump.
Is there a block in the drainage pipe (blow down it and see if it bubbles in the filter compartment). Or a block in the drain - try pouring some water down in.
Otherwise, I had the same problem (an E20 but a clean filter, no blockage and working pump) and it turned out the condenser (a large plastic vessel) or the right side of the machie (you have to take the whole back off) was full of fluff. The engineer just used a wire hanger and ran it under water to clean it out.
If you've found that it hasn't been drying the clothes fully recently that could well be the problem.
Sep 24, 2009 | Zanussi WJD1667W Front Load Washer / Dryer
Miele Premier Novo Washing Machine: Water coming straight out of the machine
The lower left panel is a filter that should be cleaned out regularly - the filter is also connected to the drain pump which rids the washer of the water. When you clean the filter out - make sure you have a bowl or Tupperware handy that holds about 2 quarts - slowly remove the filter and the water will drain into the bowl. Clean out any debris and reassemble. If the filter is not seating properly in its seat - water will leak from the small hose - the filter is what blocks the water from coming out of the hose.
Apr 05, 2008 | Miele Novotronic Premier 500 Front Load...
LG WM2688H Front Load Washer Logo
123 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
